[petsc-users] Problem with GAMG elasticity case:'createdefaultdata' not set(?) need to support NULL data!
    Einar Sørheim
    einar.sorheim at gmail.com
    Wed Oct 23 08:48:14 CDT 2013
I tried running with the following options :
-info
-malloc
-malloc_log
-malloc_dump
-malloc_debug
-memory_info
-log_summary log_summary.txt
-log
but didn't get a lot wiser however in my case would it be more efficient to
keep the ksp solver object, if so should I have one object eg. for the
thermal problem and another one for the mechanical?
The output from the end of the run:
 Total wall clock time actually solving:     856.231474
[0] PetscFinalize(): PetscFinalize() called
[0] PetscCommDuplicate(): Duplicating a communicator 1140850688 -2080374784
max tags = 2147483647
Summary of Memory Usage in PETSc
[0]Current space PetscMalloc()ed 45936, max space PetscMalloced()
1.13728e+009
[0]OS cannot compute process memory
[0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
-2080374784
[0] PetscGetHostName(): Rejecting domainname, likely is NIS CMP3.
[0] PetscFOpen(): Opening file Log.0
[0] Petsc_DelViewer(): Removing viewer data attribute in an MPI_Comm
-2080374784
[0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator
embedded in a user MPI_Comm -2080374784
[0] Petsc_DelComm_Outer(): User MPI_Comm 1140850688 is being freed after
removing reference from inner PETSc comm to this outer comm
[0] PetscCommDestroy(): Deleting PETSc MPI_Comm -2080374784
-2080374784
[0] Petsc_DelThreadComm(): Deleting thread communicator data in an MPI_Comm
-2080374784
[0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm -2080374784
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state!
[0]PETSC ERROR: PetscMallocDumpLog() called without call to
PetscMallocSetDumpLog() this is often due to
                      setting the option -malloc_log AFTER
PetscInitialize() with PetscOptionsInsert() or PetscOptionsInsertFile()!
[0]PETSC ERROR:
[0]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR:
[0]PETSC ERROR: D:\Programming\gits\Alsim\SharedModules -
Copy\Source\Release\Alsim_nypetsc.exe on a arch-mswin-c-debug named CMP3 by
admeinar Wed Oct 23 11:54:03 2013
[0]PETSC ERROR: Libraries linked from
/cygdrive/d/Programming/petsc-3.4.3/arch-mswin-c-debug/lib
[0]PETSC ERROR: Configure run at Thu Oct 17 08:23:18 2013
[0]PETSC ERROR: Configure options --with-debugging=1 --with-openmp=yes
--with-pthread=no --with-cc="win32fe icl" --with-fc="win32fe ifort"
--with-cxx="win32fe icl" --with-blas-lapack-dir="C:/Program Files
(x86)/Intel/Composer XE 2013/mkl/lib/intel64" --download-superlu
--with-sowing=0 --with-c2html=0 --with-mpi-dir="C:/Program Files
(x86)/Intel/MPI/4.1.0.028/em64t" --useThreads=0 --useThreads=0
[0]PETSC ERROR:
[0]PETSC ERROR: PetscMallocDumpLog() line 652 in
src/sys/memory/D:\PROGRA~1\PETSC-~1.3\src\sys\memory\mtr.c
[0]PETSC ERROR: PetscFinalize() line 1185 in
src/sys/objects/D:\PROGRA~1\PETSC-~1.3\src\sys\objects\pinit.c
2013/10/19 Mark F. Adams <mfadams at lbl.gov>
> You can try running a problem that finishes with
> -malloc
> -malloc_debug
> -malloc_dump
> to see if there are any memory issues.  It looks like you are completely
> destroying the solver object each time and starting over.  Valgrind would
> be very useful here because it looks like memory is getting corrupted if
> the same code runs many times.
> On Oct 19, 2013, at 3:39 PM, Einar Sørheim <einar.sorheim at gmail.com>
> wrote:
> yes, I call the given code many times, what i have seen so far is that
> changing e.g. the order of destruction statements changes the time of
> failure,I will try to debug to get more details
> 2013/10/18 Mark F. Adams <mfadams at lbl.gov>
>> I would guess there is some memory corruption or leak someplace.  Try
>> running with -on_error_attach_debugger, and try to get some more
>> information.  Do you just repeat a call to the code below many times?  Is
>> this deterministic, does it fail on the same solve each time?
>> On Oct 18, 2013, at 9:30 AM, Einar Sørheim <einar.sorheim at gmail.com>
>> wrote:
>> Uncommenting  KSPSetFromOptions solved my intial problem, however I got
>> a new problem that occurs after many timesteps, in our code we use petsc
>> gamg as a solver for several problems(e.g. thermal and mechanical) at each
>> time step, I have a suspicion it might have something to do with cleanup
>> after solving, the rror appears after many calls to the petsc gamg solver
>> interface, the error message is the following:
>> [0]PETSC ERROR:
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>> probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see
>> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
>> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
>> corruption errors
>> [0]PETSC ERROR: likely location of problem given in stack below
>> [0]PETSC ERROR: ---------------------  Stack Frames
>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
>> available,
>> [0]PETSC ERROR:       INSTEAD the line number of the start of the function
>> [0]PETSC ERROR:       is given.
>> [0]PETSC ERROR: [0] MatSetNearNullSpace line 7580
>> src/mat/interface/D:\PROGRA~1\PETSC-~1.3\src\mat\INTERF~1\matrix.c
>> [0]PETSC ERROR: Signal received!
>> [0]PETSC ERROR:
>> [0]PETSC ERROR:
>> admeinar Fri Oct 18 12:26:04 2013
>> The source code for the petsc interface:
>>       subroutine
>> petscsolver(i_nodes,r_elements_,i_rowstart_,i_columnindex_,r_x_,r_b_,i_Nnz,i_Precond,
>> i_Solver
>>      $     ,coords_,i_nodedof)
>> #include <finclude/petscsys.h>
>> #include <finclude/petscvec.h>
>> #include <finclude/petscmat.h>
>> #include <finclude/petscpc.h>
>> #include <finclude/petscksp.h>
>> #include <finclude/petscviewer.h>
>>       integer i_nodes, i_Nnz, i_Precond, i_solver, i_nodedof
>>       integer i_rowstart_(*),i_columnindex_(*)
>>       double precision r_elements_(*),r_x_(*), r_b_(*),coords_(*)
>>       integer, allocatable  :: i_indices_(:)
>> !     Variables:
>> !  A       - matrix that defines linear system
>> !  ksp    - KSP context
>> !  ksp     - KSP context
>> !  x, b, u - approx solution, RHS, exact solution vectors
>> !      implicit none
>>       Vec     x,u,b,vec_coords
>>       PC      pc
>>       Mat     A,F,Matnull
>>       KSP    ksp
>>       PetscInt i,j,II,JJ,m,n,i1,imaxiter
>>       PetscInt Istart,Iend
>>       PetscInt nsteps,one, neg_one
>>       PetscErrorCode ierr
>>       PetscBool  flg
>>       PetscScalar  v,x_array_(1), norm, tol, t0,t1
>>       PetscOffset i_x
>>       PetscViewer viewer
>>       call PetscTime(t0,ierr)
>>       write(*,*) "Enter petsc"
>>       n      = 1
>>       nsteps = 1
>>       one    = 1
>>       neg_one = 1
>>       i1 = 1
>>       imaxiter = 1200
>>       call MatCreate(PETSC_COMM_WORLD,A,ierr)
>>       call MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,i_nodes,i_nodes,ierr)
>>       call MatSetType(A, MATSEQAIJ,ierr)
>>       call MatSetUp(A,ierr)
>>       call MatSeqAIJSetPreallocation(A,100,PETSC_NULL_INTEGER,ierr)
>> !  The matrix is partitioned by contiguous chunks of rows across the
>> !  processors.  Determine which rows of the matrix are locally owned.
>>       call MatGetOwnershipRange(A,Istart,Iend,ierr)
>>       write(*,*) "Start of matrix fill", i_nodes, Istart, Iend
>>       do i=1,i_nodes
>> !         write(*,*) "Start of loop",i !!, i_indices_(i+1)
>> !         i_indices_(i+1) = i
>> !         write(*,*) "Start of loop2"
>>          do j=i_rowstart_(i),i_rowstart_(i+1)-1
>> !            write(*,*) "Start of loop 3"
>>             v = r_elements_(j)
>> !            write(*,*) i1,i,i1,j-1,v
>>             call
>> MatSetValues(A,i1,i-1,i1,i_columnindex_(j)-1,v,INSERT_VALUES,ierr)
>>             if (ierr.gt.0) stop
>>          end do
>>       end do
>> !      write(*,*) "End of matrix fill"
>> !  Assemble matrix, using the 2-step process:
>> !       MatAssemblyBegin(), MatAssemblyEnd()
>> !  Computations can be done while messages are in transition
>> !  by placing code between these two statements.
>>       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
>>       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
>> !  Create parallel vectors.
>> !   - When using VecCreate(), the parallel partitioning of the vector
>> !     is determined by PETSc at runtime.
>> !   - Note: We form 1 vector from scratch and then duplicate as needed.
>> !      write(*,*) "Start of vector fill"
>>       call VecCreate(PETSC_COMM_WORLD,u,ierr)
>>       call VecSetType(u, VECSEQ,ierr)
>>       call VecSetSizes(u,PETSC_DECIDE,i_nodes,ierr)
>> !      call VecSetFromOptions(u,ierr)
>>       call VecDuplicate(u,b,ierr)
>>       call VecDuplicate(b,x,ierr)
>>       do i=1,i_nodes
>>          call VecSetValues(x,i1,i-1,r_x_(i),INSERT_VALUES,ierr)
>>          call VecSetValues(b,i1,i-1,r_b_(i),INSERT_VALUES,ierr)
>>       enddo
>> !  Assemble vector
>>        call VecAssemblyBegin(x,ierr)
>>        call VecAssemblyEnd(x,ierr)
>>        call VecAssemblyBegin(b,ierr)
>>        call VecAssemblyEnd(b,ierr)
>>        call PetscTime(t1,ierr)
>> !       write(*,*) "End of vec fill time spent :", t1-t0
>> !  Create linear solver context
>>       call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
>> !  Set operators. Here the matrix that defines the linear system
>> !  also serves as the preconditioning matrix.
>>       call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
>>       call KSPGetPC(ksp,pc,ierr)
>>       tol = 1.e-20
>>       call
>> KSPSetTolerances(ksp,tol,PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_DOUBLE_PRECISION,imaxiter,ierr)
>>       select case (i_Precond)
>>       case ( 1 )
>>          call PCSetType(pc,PCJACOBI,ierr)
>>       case ( 2 )
>>          call PCSetType(pc,PCILU,ierr)
>>          call PCFactorSetMatSolverPackage(pc,MATSOLVERSUPERLU,ierr);
>>          call PCFactorSetUpMatSolverPackage(pc,ierr);
>>          call PCFactorGetMatrix(pc,F);
>>          call MatSuperluSetILUDropTol(F,1.e-4);
>>       case ( 3 )
>>          call PCSetType(pc,PCGAMG,ierr)
>> !         call PCGAMGInitializePackage()
>> !         call PCCreate_GAMG(pc,ierr)
>>       case DEFAULT
>>       end select
>> !      call PCSetType(pc,PCJACOBI,ierr)
>>       select case (i_solver)
>>       case ( 0 )
>>          call KSPSetType(ksp,KSPCG,ierr)
>>       case DEFAULT
>>       end select
>>       call KSPCGSetType(ksp,KSP_CG_SYMMETRIC,ierr)
>>       if (i_nodedof==3) then
>>          write(*,*) "Set coord, number of nodes is:", i_nodes/i_nodedof
>>          call
>> VecCreateSeqWithArray(MPI_COMM_SELF,3,i_nodes,coords_,vec_coords,ierr)
>>          call MatNullSpaceCreateRigidBody(vec_coords,Matnull,ierr)
>>          call MatSetNearNullSpace(A,Matnull,ierr)
>>          call MatNullSpaceDestroy(Matnull,ierr)
>>          write(*,*) "Finish setting null space ierr =", ierr
>> !         call PCSetCoordinates( pc, 3,i_nodes/i_nodedof, coords_, ierr )
>>       end if
>> !      call KSPMonitorSet(ksp, KSPMonitorDefault, PETSC_NULL,
>> PETSC_NULL,ierr)
>> !  Set runtime options, e.g.,
>> !      -ksp_type <type> -pc_type <type> -ksp_monitor -ksp_rtol <rtol>
>> !  These options will override those specified above as long as
>> !  KSPSetFromOptions() is called _after_ any other customization
>> !  routines.
>>       call KSPSetFromOptions(ksp,ierr)
>>       call KSPSetInitialGuessNonzero(ksp,PETSC_TRUE,ierr)
>>       call KSPSetUp(ksp,ierr)
>>       write(*,*) "Time setup", t0-t1
>> !                      Solve the linear system
>>       call KSPSolve(ksp,b,x,ierr)
>>       write(*,*) "end solve, time used:",t1-t0
>>       call KSPGetSolution(ksp,x,ierr)
>>       call VecGetArray(x,x_array_,i_x,ierr)
>>       do i=1,i_nodes
>>          r_x_(i) = x_array_(i_x + i)
>>       enddo
>>       call VecRestoreArray(x,x_array_,i_x,ierr)
>> !  Free work space.  All PETSc objects should be destroyed when they
>> !  are no longer needed.
>> !      call PCDestroy(pc,ierr)
>>       call VecDestroy(u,ierr)
>>       call VecDestroy(x,ierr)
>>       call VecDestroy(b,ierr)
>>       call MatDestroy(A,ierr)
>>          call VecDestroy(vec_coords,ierr)
>>          call MatDestroy(Matnull,ierr)
>>       endif
>>       call KSPDestroy(ksp,ierr)
>>       write(*,*) "time celan up :", t0-t1
>>       end
>> Einar Sørheim
>> <Mail Attachment>
> Einar Sørheim
Einar Sørheim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131023/d10bfa62/attachment-0001.html>
