[petsc-users] Fwd: How PETSc solves Ax=b in parallel
Matthew Knepley
knepley at gmail.com
Tue Oct 22 15:25:07 CDT 2013
On Tue, Oct 22, 2013 at 3:16 PM, paul zhang <paulhuaizhang at gmail.com> wrote:
> That is a good one. I mean for my case. which method can I try?
Both those direct methods are parallel (SuperLU_dist and MUMPS).
Matt
> On Tue, Oct 22, 2013 at 4:14 PM, Matthew Knepley <knepley at gmail.com>wrote:
>> On Tue, Oct 22, 2013 at 3:12 PM, paul zhang <paulhuaizhang at gmail.com>wrote:
>>> One more question, can I solve the system in parallel?
>> Yes, or you would be using ETSC :)
>> Matt
>>> On Tue, Oct 22, 2013 at 4:08 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Tue, Oct 22, 2013 at 3:04 PM, huaibao zhang <paulhuaizhang at gmail.com
>>>> > wrote:
>>>>> Thanks for the answer. It makes sense.
>>>>> However, in my case, matrix A is huge and rather sparse, which also
>>>>> owns a pretty good diagonal structure although there are some other
>>>>> elements are nonzero. I have to look for a better way to solve the system
>>>>> more efficiently. If in parallel, it is even better.
>>>>> Attached is an example for A's structure. The pink block is a matrix
>>>>> with 10x10 elements. The row or column in my case can be in million size.
>>>> The analytic character of the operator is usually more important than
>>>> the sparsity structure for scalable solvers.
>>>> The pattern matters a lot for direct solvers, and you should definitely
>>>> try them (SuperLU_dist or MUMPS in PETSc).
>>>> If they use too much memory or are too slow, then you need to
>>>> investigate good preconditioners for iterative methods.
>>>> Matt
>>>>> Thanks again.
>>>>> Paul
>>>>> Huaibao (Paul) Zhang
>>>>> *Gas Surface Interactions Lab*
>>>>> Department of Mechanical Engineering
>>>>> University of Kentucky,
>>>>> Lexington, KY, 40506-0503
>>>>> *Office*: 216 Ralph G. Anderson Building
>>>>> *Web*:gsil.engineering.uky.edu
>>>>> On Oct 21, 2013, at 12:53 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>> On Mon, Oct 21, 2013 at 11:23 AM, paul zhang <paulhuaizhang at gmail.com>wrote:
>>>>>> Hi Jed,
>>>>>> Thanks a lot for your answer. It really helps. I built parts of the
>>>>>> matrix on each processor, then collected them into a global one according
>>>>>> to their global position. Actually I used two MPI function instead of the
>>>>>> one in the example, where the local size, as well as the global size is
>>>>>> given.
>>>>>> VecCreateMPI and MatCreateMPIAIJ. It does not really matter right?
>>>>>> My continuing question is since the iteration for the system is
>>>>>> global. Is it more efficient if I solve locally instead. ie. solve parts on
>>>>>> each of the processor instead of doing globally.
>>>>> No, because this ignores the coupling between domains.
>>>>> Matt
>>>>>> Thanks again,
>>>>>> Paul
>>>>>> On Mon, Oct 21, 2013 at 11:42 AM, Jed Brown <jedbrown at mcs.anl.gov>wrote:
>>>>>>> paul zhang <paulhuaizhang at gmail.com> writes:
>>>>>>> > I am using KSP, more specifically FGMRES method, with MPI to solve
>>>>>>> Ax=b
>>>>>>> > system. Here is what I am doing. I cut my computation domain into
>>>>>>> many
>>>>>>> > pieces, in each of them I compute independently by solving fluid
>>>>>>> equations.
>>>>>>> > This has nothing to do with PETSc. Finally, I collect all of the
>>>>>>> > information and load it to a whole A matrix.
>>>>>>> I hope you build parts of this matrix on each processor, as is done
>>>>>>> in
>>>>>>> the examples. Note the range Istart to Iend here:
>>>>>>> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex2.c.html
>>>>>>> > My question is how PETSc functions work in parallel in my case.
>>>>>>> There are
>>>>>>> > two guesses to me. First, PETSc solves its own matrix for each
>>>>>>> domain using
>>>>>>> > local processor, although A is a global. For the values like
>>>>>>> number of
>>>>>>> > iterations, solution vector, their numbers should have equaled to
>>>>>>> the
>>>>>>> > number of processors I applied, but I get only one value for each
>>>>>>> of them.
>>>>>>> > The reason is that the processors must talk with each other once
>>>>>>> all of
>>>>>>> > their work is done, that is why I received the "all reduced"
>>>>>>> value. This is
>>>>>>> > more logical than my second guess.
>>>>>>> It does not work because the solution operators are global, so to
>>>>>>> solve
>>>>>>> the problem, the iteration must be global.
>>>>>>> > In the second one, the system is solved in parallel too. But PETSc
>>>>>>> function
>>>>>>> > redistributes the global sparse matrix A to each of the processors
>>>>>>> after
>>>>>>> > its load is complete. That is to say now each processor may not
>>>>>>> solve the
>>>>>>> > its own partition matrix.
>>>>>>> Hopefully you build the matrix already-distributed. The default
>>>>>>> _preconditioner_ is local, but the iteration is global. PETSc does
>>>>>>> not
>>>>>>> "redistribute" the matrix automatically, though if you call
>>>>>>> MatSetSizes() and pass PETSC_DECIDE for the local sizes, PETSc will
>>>>>>> choose them.
>>>>>> Lexington,
>>>>>> KY, 40506-0503*
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Lexington,
>>> KY, 40506-0503*
>> experiments lead.
>> -- Norbert Wiener
> Lexington,
> KY, 40506-0503*
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131022/a11a0a17/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131022/a11a0a17/attachment-0001.png>
