[petsc-users] Fwd: How PETSc solves Ax=b in parallel
    Matthew Knepley
    knepley at gmail.com
    Tue Oct 22 15:08:16 CDT 2013
On Tue, Oct 22, 2013 at 3:04 PM, huaibao zhang <paulhuaizhang at gmail.com>wrote:
> Thanks for the answer. It makes sense.
> However, in my case, matrix A is huge and rather sparse, which also owns a
> pretty good diagonal structure although there are some other elements are
> nonzero. I have to  look for a better way to solve the system more
> efficiently. If in parallel, it is even better.
> Attached is an example for A's structure. The pink block is a matrix with
> 10x10 elements. The row or column in my case can be in million size.
The analytic character of the operator is usually more important than the
sparsity structure for scalable solvers.
The pattern matters a lot for direct solvers, and you should definitely try
them (SuperLU_dist or MUMPS in PETSc).
If they use too much memory or are too slow, then you need to investigate
good preconditioners for iterative methods.
   Matt
> Thanks again.
> Paul
> Huaibao (Paul) Zhang
> *Gas Surface Interactions Lab*
> Department of Mechanical Engineering
> University of Kentucky,
> Lexington, KY, 40506-0503
> *Office*: 216 Ralph G. Anderson Building
> *Web*:gsil.engineering.uky.edu
> On Oct 21, 2013, at 12:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 21, 2013 at 11:23 AM, paul zhang <paulhuaizhang at gmail.com>wrote:
>> Hi Jed,
>> Thanks a lot for your answer. It really helps. I built parts of the
>> matrix on each processor, then collected them into a global one according
>> to their global position. Actually I used two MPI function instead of the
>> one in the example, where the local size, as well as the global size is
>> given.
>> VecCreateMPI and MatCreateMPIAIJ. It does not really matter right?
>> My continuing question is since the iteration for the system is global.
>> Is it more efficient if I solve locally instead. ie. solve parts on each of
>> the processor instead of doing globally.
> No, because this ignores the coupling between domains.
>   Matt
>> Thanks again,
>> Paul
>> On Mon, Oct 21, 2013 at 11:42 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> paul zhang <paulhuaizhang at gmail.com> writes:
>>> > I am using KSP, more specifically FGMRES method, with MPI to solve Ax=b
>>> > system. Here is what I am doing. I cut my computation domain into many
>>> > pieces, in each of them I compute independently by solving fluid
>>> equations.
>>> > This has nothing to do with PETSc. Finally, I collect all of the
>>> > information and load it to a whole A matrix.
>>> I hope you build parts of this matrix on each processor, as is done in
>>> the examples.  Note the range Istart to Iend here:
>>> http://www.mcs.anl.gov/petsc/petsc-current/src/ksp/ksp/examples/tutorials/ex2.c.html
>>> > My question is how PETSc functions work in parallel in my case. There
>>> are
>>> > two guesses to me. First, PETSc solves its own matrix for each domain
>>> using
>>> > local processor, although A is a global. For the values like number of
>>> > iterations, solution vector, their numbers should have equaled to the
>>> > number of processors I applied, but I get only one value for each of
>>> them.
>>> > The reason is that the processors must talk with each other once all of
>>> > their work is done, that is why I received the "all reduced" value.
>>> This is
>>> > more logical than my second guess.
>>> It does not work because the solution operators are global, so to solve
>>> the problem, the iteration must be global.
>>> > In the second one, the system is solved in parallel too. But PETSc
>>> function
>>> > redistributes the global sparse matrix A to each of the processors
>>> after
>>> > its load is complete. That is to say now each processor may not solve
>>> the
>>> > its own partition matrix.
>>> Hopefully you build the matrix already-distributed.  The default
>>> _preconditioner_ is local, but the iteration is global.  PETSc does not
>>> "redistribute" the matrix automatically, though if you call
>>> MatSetSizes() and pass PETSC_DECIDE for the local sizes, PETSc will
>>> choose them.
>> Lexington,
>> KY, 40506-0503*
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131022/40ae0d9d/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131022/40ae0d9d/attachment.png>
