[petsc-users] memory use of a DMDA
    Matthew Knepley
    knepley at gmail.com
    Mon Oct 21 13:04:43 CDT 2013
On Mon, Oct 21, 2013 at 1:00 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Matt,
>    The scatters should always use block indices (I think they do) so the
> memory usage for the scatters should not have a dof* in front of this. Are
> you sure that the dof* is there? If it is there is it because it is a block
> size that we don't support directly?  We currently have special support for
> BS or 1,2,3,4,5,6,7,8,12    We should at least fill in 9,10,11
>     Do we somewhere inside the VecScatter create business mistakenly
> create an array that depends on dof*?
I am sure of this dependence. Its very easy to see by just creating the DA
and ending using -malloc_test. If it is intended to use block indices,
this is not happening.
   Matt
>    Barry
> On Oct 21, 2013, at 11:52 AM, Matthew Knepley <knepley at gmail.com> wrote:
> > On Mon, Oct 21, 2013 at 11:32 AM, Barry Smith <bsmith at mcs.anl.gov>
> wrote:
> >    The PETSc DMDA object greedily allocates several arrays of data used
> to set up the communication and other things like local to global mappings
> even before you create any vectors. This is why you see this big bump in
> memory usage.
> >    BUT I don't think it should be any worse in 3.4 than in 3.3 or
> earlier; at least we did not intend to make it worse. Are you sure it is
> using more memory than in 3.3
> >    In order for use to decrease the memory usage of the DMDA setup it
> would be helpful if we knew which objects created within it used the most
> memory.  There is some sloppiness in that routine of not reusing memory as
> well as could be, not sure how much difference that would make.
> > I am adding a DMDA example to look at this is detail. Here is what I
> have up front. Suppose that there are G grid vertices, e,g, 10^6 in
> > your example, so that a vector takes up dof*8G bytes. Then the 2D DMDA
> allocates
> >   Create ltog scatter          dof*8G
> >   Create gtol scatter          dof*8G
> >   Raw indices                    dof*4G
> >   Create ltogmap               dof*4G
> >   Create ltogmapb                   4G
> >                                             dof*24G + 4G < 4 vectors
> > It also allocates 2 temporary vectors which are freed but your test may
> pick up since the OS might not have garbage collected them. I will
> > get the precise numbers for 3D, but they should be similar.
> > I don't really see the point of using a DMDA without the scatters. You
> could save 1 vector of storage by making the creation of the l2g maps
> > for the global vector lazy (and possibly those indices we use to remap
> arrays).
> >    Matt
> >    Barry
> > On Oct 21, 2013, at 7:02 AM, Juha Jäykkä <juhaj at iki.fi> wrote:
> > > Dear list members,
> > > I have noticed strange memory consumption after upgrading to 3.4
> series. I
> > > never had time to properly investigate, but here is what happens [yes,
> this
> > > might be a petsc4py issue, but I doubt it] is
> > > # helpers contains _ProcessMemoryInfoProc routine which just digs the
> memory
> > > # usage data from /proc
> > > import helpers
> > > procdata=helpers._ProcessMemoryInfoProc()
> > > print procdata.rss/2**20, "MiB /", procdata.os_specific[3][1]
> > > from petsc4py import PETSc
> > > da = PETSc.DA().create(sizes=[100,100,100],
> proc_sizes=[PETSc.DECIDE,PETSc.DECIDE,PETSc.DECIDE],
> > >                       boundary_type=[3,0,0],
> > >                       stencil_type=PETSc.DA.StencilType.BOX,
> > >                       dof=7, stencil_width=1, comm=PETSc.COMM_WORLD)
> > > vec=da.createGlobalVec()
> > > outputs
> > > 48 MiB / 49348 kB
> > > 48 MiB / 49360 kB
> > > 381 MiB / 446228 kB
> > > 435 MiB / 446228 kB
> > > Which is odd: size of the actual data to be stored in the da is just
> about 56
> > > megabytes, so why does creating the da consume 7 times that? And why
> does the
> > > DA reserve the memory in the first place? I thought memory only gets
> allocated
> > > once an associated vector is created and it indeed looks like the
> > > createGlobalVec call does indeed allocate the right amount of data.
> But what
> > > is that 330 MiB that DA().create() consumes? [It's actually the
> .setUp()
> > > method that does the consuming, but that's not of much use as it needs
> to be
> > > called before a vector can be created.]
> > > Cheers,
> > > Juha
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131021/6dc918a6/attachment-0001.html>
