[petsc-users] memory use of a DMDA
Matthew Knepley
knepley at gmail.com
Mon Oct 21 11:52:13 CDT 2013
On Mon, Oct 21, 2013 at 11:32 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> The PETSc DMDA object greedily allocates several arrays of data used to
> set up the communication and other things like local to global mappings
> even before you create any vectors. This is why you see this big bump in
> memory usage.
> BUT I don't think it should be any worse in 3.4 than in 3.3 or earlier;
> at least we did not intend to make it worse. Are you sure it is using more
> memory than in 3.3
> In order for use to decrease the memory usage of the DMDA setup it
> would be helpful if we knew which objects created within it used the most
> memory. There is some sloppiness in that routine of not reusing memory as
> well as could be, not sure how much difference that would make.
I am adding a DMDA example to look at this is detail. Here is what I have
up front. Suppose that there are G grid vertices, e,g, 10^6 in
your example, so that a vector takes up dof*8G bytes. Then the 2D DMDA
allocates
Create ltog scatter dof*8G
Create gtol scatter dof*8G
Raw indices dof*4G
Create ltogmap dof*4G
Create ltogmapb 4G
dof*24G + 4G < 4 vectors
It also allocates 2 temporary vectors which are freed but your test may
pick up since the OS might not have garbage collected them. I will
get the precise numbers for 3D, but they should be similar.
I don't really see the point of using a DMDA without the scatters. You
could save 1 vector of storage by making the creation of the l2g maps
for the global vector lazy (and possibly those indices we use to remap
arrays).
Matt
> Barry
> On Oct 21, 2013, at 7:02 AM, Juha Jäykkä <juhaj at iki.fi> wrote:
> > Dear list members,
> > I have noticed strange memory consumption after upgrading to 3.4 series.
> I
> > never had time to properly investigate, but here is what happens [yes,
> this
> > might be a petsc4py issue, but I doubt it] is
> > # helpers contains _ProcessMemoryInfoProc routine which just digs the
> memory
> > # usage data from /proc
> > import helpers
> > procdata=helpers._ProcessMemoryInfoProc()
> > print procdata.rss/2**20, "MiB /", procdata.os_specific[3][1]
> > from petsc4py import PETSc
> > da = PETSc.DA().create(sizes=[100,100,100],
> proc_sizes=[PETSc.DECIDE,PETSc.DECIDE,PETSc.DECIDE],
> > boundary_type=[3,0,0],
> > stencil_type=PETSc.DA.StencilType.BOX,
> > dof=7, stencil_width=1, comm=PETSc.COMM_WORLD)
> > vec=da.createGlobalVec()
> > outputs
> > 48 MiB / 49348 kB
> > 48 MiB / 49360 kB
> > 381 MiB / 446228 kB
> > 435 MiB / 446228 kB
> > Which is odd: size of the actual data to be stored in the da is just
> about 56
> > megabytes, so why does creating the da consume 7 times that? And why
> does the
> > DA reserve the memory in the first place? I thought memory only gets
> allocated
> > once an associated vector is created and it indeed looks like the
> > createGlobalVec call does indeed allocate the right amount of data. But
> what
> > is that 330 MiB that DA().create() consumes? [It's actually the .setUp()
> > method that does the consuming, but that's not of much use as it needs
> to be
> > called before a vector can be created.]
> > Cheers,
> > Juha
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131021/dc6abf47/attachment.html>
