[petsc-users] Geometric MG as Solver & Preconditioner for FEM/Spectral/FD
Jed Brown
jedbrown at mcs.anl.gov
Fri Oct 18 10:28:42 CDT 2013
Shiva Rudraraju <rudraa at umich.edu> writes:
>>I did unstructured hexes. You still haven't said what you'll use for relaxation.
> High-order discretizations tend to have poor h-ellipticity, so they either
> need heavy smoothers or a correction based on a discretization with better
> h-ellipticity.
> Quite frankly, I was not aware of the poor h-ellipticity of higher order
> elements and I was assuming I would use the regular GS/GMRES/etc for
> relaxation. I looked up h-ellipticity of higher order elements and now this
> adds to my worries :(. I may be asking for too much here.... but what do
> you mean by heavy smoothers? or correction based on a discretization?.
You can use one discretization for evaluating residuals, but then use an
embedded low-order discretization to apply the correction. See "defect
correction" in Achi's multigrid guide or in Trottenberg.
The paper I mentioned earlier was doing something simpler and less
intrusive: assemble the embedded low-order operator and feed it to
algebraic multigrid, but evaluate residuals matrix-free using the
high-order discretization. But if you have a reasonable geometric
hierarchy, the defect correction schemes are better.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131018/08523986/attachment.pgp>
