[petsc-users] Dense Matrix setting local rows / local columns Question
James A Charles charlesj at purdue.edu
Thu Oct 17 10:02:45 CDT 2013
Hello,
I'm trying to use a Dense Parallel matrix where there are no nonzeros that is rectangular of size Nxp where N >> p. P is anywhere from 2-6 typically and N can be of size 1E6 or more.
For this I would like to only distribute the rows along the MPI processes and not have the columns distributed at all (local columns size = global column size). What is the best way to do this in Petsc? If it matters I am using Petsc3.4.
The operations performed after the Matrix allocation are:
direct call to Lapack for QR factorization via pointer to array.
Matrix multiply with an NxN matrix.
I have this working in serial but when I try to distribute my matrices I get columns with size p*(number of processes).
James
