[petsc-users] signal received error; MatNullSpaceTest; Stokes flow solver with pc fieldsplit and schur complement
Thu Oct 17 09:39:20 CDT 2013
Bishesh Khanal <bisheshkh at gmail.com> writes:
>> I tried running on the cluster with one core per node with 4 nodes and I
> got the following errors (note: using valgrind, and openmpi of the cluster)
> at the very end after the many usual "unconditional jump ... errors"  which
> might be interesting
> mpiexec: killing job...
> mpiexec: abort is already in progress...hit ctrl-c again to forcibly
> terminate
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 59.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the
> batch system) has told this process to end
Memory corruption generally results in SIGSEGV, so I suspect this is
still either a memory issue or some other resource issue.  How much
memory is available on these compute nodes?  Do turn off Valgrind for
this run; it takes a lot of memory.
> Does it mean it is crashing near MatSetValues_MPIAIJ ?
Possibly, but it could be killing the program for other reasons.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131017/d7c13a03/attachment.pgp>
