[petsc-users] Suggestions for code with dof >> 1 ?
Christophe Ortiz
christophe.ortiz at ciemat.es
Thu Oct 17 05:00:48 CDT 2013
On Wed, Oct 16, 2013 at 4:22 PM, Christophe Ortiz <
christophe.ortiz at ciemat.es> wrote:
> On Wed, Oct 16, 2013 at 4:10 PM, Christophe Ortiz <
>> On Wed, Oct 16, 2013 at 3:36 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>> Christophe Ortiz <christophe.ortiz at ciemat.es> writes:
>>> > I found where is the problem. I had
>>> > set TSARKIMEXSetFullyImplicit(ts,PETSC_TRUE);
>>> > I found it produces wrong solutions, either with ARKIMEX3, 1BEE or A2.
>>> > Solution becomes negative. Without this option, all ARKIMEX types work
>>> very
>>> > well and very fast.
>>> I'm glad they work as IMEX methods (please check that the solutions are
>>> correct), but I would like to find out why they are not working in fully
>>> implicit mode. Is your problem similar to ex25?
>> Yes. The only difference is that I put everything (diffusion and reaction
>> terms) under IFunction and IJacobian.
>> My system is
>> u_t - alpha.u_xx + k.u.v = 0
>> v_t - beta.v_xx + k.u.v = 0
>> with Dirichlet boundary conditions
>> u(x=0,t) = u(x=L,t) = cste
>> v(x=0,t) = v(x=L,t) = cste
>> (If I remember
>>> correctly, that example uses a DAE formulation for boundary conditions
>>> and thus has trouble with some methods with explicit stages. There may
>>> be more going on.)
>> Now you say it, I'm having some troubles. After checking that it worked
>> very well with only diffusion terms with ARKIMEX, I introduced the reaction
>> term. With ARKIMEX 1BEE/A2, it goes very fast up to t=0.27 s, then, steps
>> start being rejected and then it goes very slowly, with small timesteps.
>> See output below.
>> Do you think it is due to the fact that I use IFunction to define
>> boundary conditions, which produces troubles with ARKIMEX methods ?
>> What would be the solution ?
>> Christophe
> I just tried with TSARKIMEXSetFullyImplicit(ts,PETSC_TRUE); It goes much
> better and reaches final time....but solution is clearly not correct. The
> initial gaussian distributions do not change. Like if diffusion was null.
I've tried something else. Since ARKIMEX is able to converge up to t~0.20s
and gives the correct solution for this time, and then comes into trouble,
I thought that it could come from the SNES.
Then, instead of using SNESNEWTONLS, I tried SNESNEWTONTR. I summarize my
findings:
- With NEWTONTR, ARKIMEX (3, 1BEE or A2) converges.
-With NEWTONTR, ARKIMEX 3 converges much faster than 1BEE or A2 (much less
timesteps).
- No conflicts between NEWTONTR and ARKIMEXFullyImplicit as with NEWTONLS.
Give the same results.
Then I came back to SNESNEWTONLS
- With NEWTONLS, ARKIMEX does not converges.
- When ARKIMEXFullyImplicit is used with NEWTONLS, it converges, but
solution clearly incorrect. It seems it does nothing, initial distributions
do not change.
And I played a bit with the tolerances:
- No influence of rtol (increasing or decreasing it). It stops at same
point.
- Changing stol from 1e-8 to 1e-7 seems to ease as it goes up to longer
time (6.98 s instead of 0.20) but then stops with an error:
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Floating point exception!
[0]PETSC ERROR: Vec entry at local location 450 is not-a-number or infinite
at end of function: Parameter number 3!
[0]PETSC ERROR: VecValidValues() line 30 in src/vec/vec/interface/rvector.c
[0]PETSC ERROR: SNESComputeFunction() line 1998 in src/snes/interface/snes.c
[0]PETSC ERROR: SNESSolve_NEWTONLS() line 162 in src/snes/impls/ls/ls.c
[0]PETSC ERROR: SNESSolve() line 3636 in src/snes/interface/snes.c
[0]PETSC ERROR: TSStep_ARKIMEX() line 765 in src/ts/impls/arkimex/arkimex.c
[0]PETSC ERROR: TSStep() line 2458 in src/ts/interface/ts.c
[0]PETSC ERROR: TSSolve() line 2583 in src/ts/interface/ts.c
[0]PETSC ERROR: main() line 392 in src/ts/examples/tutorials/diffusion.c
Maybe all this will give you a hint of what's going on...
Saludos,
Christophe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131017/40a3f639/attachment.html>
