[petsc-users] Problem with GAMG elasticity case:'createdefaultdata' not set(?) need to support NULL data!
Jed Brown
jedbrown at mcs.anl.gov
Wed Oct 16 21:38:34 CDT 2013
"Mark F. Adams" <mfadams at lbl.gov> writes:
> I pushed a pull request to fix this. You should not fail here but you
> should always use KSPSetFromOptions anyway.
Amended PR and merged to 'next'.
Mark, relative to your patch, I simplified setting and took out the
now-unnecessary logic in PCSetFromOptions_GAMG.
commit bd94a7aa4cff05a8b49c3b8be9fd5e557f431631
Author: Jed Brown <jedbrown at mcs.anl.gov>
Date: Wed Oct 16 18:45:43 2013 -0400
PCGAMG: set default type (AGG); PCSetUp_GAMG crashes if not set
If PCSetFromOptions had not been called, PCSetUp_GAMG would crash due to
missing subtype. It is more conventional with top-level objects to use
a lazy choice of type, but there is no great setup involved, and no
known order-dependence, so it looks safe to simply set the type to the
default value (AGG) up-front.
Reported-by: Einar Sørheim <einar.sorheim at gmail.com>
Based-on-patch-by: Mark Adams <mfadams at lbl.gov>
diff --git a/src/ksp/pc/impls/gamg/gamg.c b/src/ksp/pc/impls/gamg/gamg.c
index 39b3ac4..dadb0e2 100644
--- a/src/ksp/pc/impls/gamg/gamg.c
+++ b/src/ksp/pc/impls/gamg/gamg.c
@@ -1275,12 +1275,11 @@ PetscErrorCode PCSetFromOptions_GAMG(PC pc)
/* -pc_gamg_type */
- char tname[256] = PCGAMGAGG;
- const char *deftype = pc_gamg->gamg_type_name ? pc_gamg->gamg_type_name : tname;
- ierr = PetscOptionsList("-pc_gamg_type","Type of AMG method","PCGAMGSetType",GAMGList, tname, tname, sizeof(tname), &flag);CHKERRQ(ierr);
+ char tname[256];
+ ierr = PetscOptionsList("-pc_gamg_type","Type of AMG method","PCGAMGSetType",GAMGList, pc_gamg->gamg_type_name, tname, sizeof(tname), &flag);CHKERRQ(ierr);
/* call PCCreateGAMG_XYZ */
- if (flag || !pc_gamg->gamg_type_name) {
- ierr = PCGAMGSetType(pc, flag ? tname : deftype);CHKERRQ(ierr);
+ if (flag) {
+ ierr = PCGAMGSetType(pc,tname);CHKERRQ(ierr);
/* -pc_gamg_verbose */
@@ -1468,7 +1467,8 @@ PETSC_EXTERN PetscErrorCode PCCreate_GAMG(PC pc)
#endif
#endif
+ /* PCSetUp_GAMG assumes that the type has been set, so set it to the default now */
+ ierr = PCGAMGSetType(pc,PCGAMGAGG);CHKERRQ(ierr);
PetscFunctionReturn(0);
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131016/1600440e/attachment.pgp>
