[petsc-users] signal received error; MatNullSpaceTest; Stokes flow solver with pc fieldsplit and schur complement
Bishesh Khanal bisheshkh at gmail.com
Wed Oct 16 12:55:29 CDT 2013
On Wed, Oct 16, 2013 at 5:50 PM, Mark F. Adams <mfadams at lbl.gov> wrote:
> You might also test with Jacobi as a sanity check.
> On Oct 16, 2013, at 11:19 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> > especially the GAMG version which you also try in the debugger with the
> argument -start_in_debugger
> > On Oct 16, 2013, at 9:32 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> >> Sounds like a memory error.
> >> I'd run your code through valgrind to double check. The error could be
> completely unconnected to the nullspaces.
Thanks, I tried them, but has not worked yet. Here are couple of things I
tried, running valgrind with one and multiple processors for a smaller
sized domains where there is no runtime error thrown. The results are shown
below:
(I've run valgrind in the cluster for the bigger sized domain where it
would throw run-time error, but it's still running, valgrind slowed down
the execution I guess).
1******* ********** For smaller domain sizes ((i.e. the sizes for which the
program runs and gives results) ******************
With one processor, valgrind does NOT give any errors.
With multiple processes it reports something but I'm not sure if they are
errors related to my code. One example with two processes:
petsc -n 2 valgrind src/AdLemMain -pc_type fieldsplit -pc_fieldsplit_type
schur -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2
-pc_fieldsplit_1_fields 3 -fieldsplit_0_pc_type hypre
-fieldsplit_0_ksp_converged_reason -ksp_converged_reason
==31715== Memcheck, a memory error detector
==31716== Memcheck, a memory error detector
==31716== Copyright (C) 2002-2010, and GNU GPL'd, by Julian Seward et al.
==31716== Using Valgrind-3.6.1 and LibVEX; rerun with -h for copyright info
==31716== Command: src/AdLemMain -pc_type fieldsplit -pc_fieldsplit_type
==31716==
==31715== Copyright (C) 2002-2010, and GNU GPL'd, by Julian Seward et al.
==31715== Using Valgrind-3.6.1 and LibVEX; rerun with -h for copyright info
==31715== Command: src/AdLemMain -pc_type fieldsplit -pc_fieldsplit_type
==31715==
==31716== Conditional jump or move depends on uninitialised value(s)
==31716==    at 0x32EEED9BCE: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==31716==    by 0x32EEED9155: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==31716==    by 0x32EEE185D7: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==31716==    by 0x32ECC0F195: call_init.part.0 (in /lib64/ld-2.14.90.so)
==31716==    by 0x32ECC0F272: _dl_init (in /lib64/ld-2.14.90.so)
==31716==    by 0x32ECC01719: ??? (in /lib64/ld-2.14.90.so)
==31716==    by 0xE: ???
==31716==    by 0x7FF0003EE: ???
==31716==    by 0x7FF0003FC: ???
==31716==    by 0x7FF000405: ???
==31716==    by 0x7FF000410: ???
==31716==    by 0x7FF000424: ???
==31716==
==31716==    at 0x32EEED9BD9: ??? (in /usr/lib64/libgfortran.so.3.0.0)
==31716==
dmda of size: (8,8,8)
 using schur complement
 using user defined split
  Linear solve converged due to CONVERGED_ATOL iterations 0
  Linear solve converged due to CONVERGED_RTOL iterations 3
Linear solve converged due to CONVERGED_RTOL iterations 1
==31716==
==31716== HEAP SUMMARY:
==31716==     in use at exit: 212,357 bytes in 1,870 blocks
==31716==   total heap usage: 112,701 allocs, 110,831 frees, 19,698,341
bytes allocated
==31716==
==31715==
==31715== HEAP SUMMARY:
==31715==     in use at exit: 187,709 bytes in 1,864 blocks
==31715==   total heap usage: 112,891 allocs, 111,027 frees, 19,838,487
bytes allocated
==31715==
==31716== LEAK SUMMARY:
==31716==    definitely lost: 0 bytes in 0 blocks
==31716==    indirectly lost: 0 bytes in 0 blocks
==31716==      possibly lost: 0 bytes in 0 blocks
==31716==    still reachable: 212,357 bytes in 1,870 blocks
==31716==         suppressed: 0 bytes in 0 blocks
==31716== Rerun with --leak-check=full to see details of leaked memory
==31716==
==31716== For counts of detected and suppressed errors, rerun with: -v
==31716== Use --track-origins=yes to see where uninitialised values come
from
==31716== ERROR SUMMARY: 2 errors from 2 contexts (suppressed: 2 from 2)
==31715== LEAK SUMMARY:
==31715==    definitely lost: 0 bytes in 0 blocks
==31715==    indirectly lost: 0 bytes in 0 blocks
==31715==      possibly lost: 0 bytes in 0 blocks
==31715==    still reachable: 187,709 bytes in 1,864 blocks
==31715==         suppressed: 0 bytes in 0 blocks
==31715== Rerun with --leak-check=full to see details of leaked memory
==31715==
==31715== For counts of detected and suppressed errors, rerun with: -v
==31715== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 2 from 2)
2*************************** For the small size of 18X18X18 grid (the
solver converges, -fieldsplit_0 pc jacobi used) *********************
The results when I run valgrind for 2 processes, some errors:
==18003== Syscall param writev(vector[...]) points to uninitialised byte(s)
==18003==    at 0x962E047: writev (in /lib64/libc-2.14.90.so)
==18003==    by 0xBB34E22: mca_oob_tcp_msg_send_handler (oob_tcp_msg.c:249)
==18003==    by 0xBB35D52: mca_oob_tcp_peer_send (oob_tcp_peer.c:204)
==18003==    by 0xBB39A36: mca_oob_tcp_send_nb (oob_tcp_send.c:167)
==18003==    by 0xB92AB10: orte_rml_oob_send (rml_oob_send.c:136)
==18003==    by 0xB92B0BF: orte_rml_oob_send_buffer (rml_oob_send.c:270)
==18003==    by 0xBF44147: modex (grpcomm_bad_module.c:573)
==18003==    by 0x81162B1: ompi_mpi_init (ompi_mpi_init.c:541)
==18003==    by 0x812EC31: PMPI_Init_thread (pinit_thread.c:84)
==18003==    by 0x4F903D9: PetscInitialize (pinit.c:675)
==18003==    by 0x505088: main (PetscAdLemMain.cxx:25)
==18003==  Address 0xfdf9d45 is 197 bytes inside a block of size 512 alloc'd
==18003==    at 0x4C2A5B2: realloc (vg_replace_malloc.c:525)
==18003==    by 0x81A4286: opal_dss_buffer_extend
(dss_internal_functions.c:63)
==18003==    by 0x81A4685: opal_dss_copy_payload (dss_load_unload.c:164)
==18003==    by 0x817C07E: orte_grpcomm_base_pack_modex_entries
(grpcomm_base_modex.c:861)
==18003==    by 0xBF44042: modex (grpcomm_bad_module.c:563)
==18003==
Then the solver converges
and again some errors (I doubt if they are caused from my code at all:)
==18003== Conditional jump or move depends on uninitialised value(s)
==18003==    at 0xDDCC1B2: rdma_destroy_id (in
/usr/lib64/librdmacm.so.1.0.0)
==18003==    by 0xE200A23: id_context_destructor
(btl_openib_connect_rdmacm.c:185)
==18003==    by 0xE1FFED0: rdmacm_component_finalize (opal_object.h:448)
==18003==    by 0xE1FE3AA: ompi_btl_openib_connect_base_finalize
(btl_openib_connect_base.c:496)
==18003==    by 0xE1EA9E6: btl_openib_component_close
(btl_openib_component.c:251)
==18003==    by 0x81BD411: mca_base_components_close
(mca_base_components_close.c:53)
==18003==    by 0x8145E1F: mca_btl_base_close (btl_base_close.c:62)
==18003==    by 0xD5A3DE8: mca_pml_ob1_component_close
(pml_ob1_component.c:156)
==18003==    by 0x8154E37: mca_pml_base_close (pml_base_close.c:66)
==18003==    by 0x8117142: ompi_mpi_finalize (ompi_mpi_finalize.c:306)
==18003==    by 0x4F94D6D: PetscFinalize (pinit.c:1276)
==180
==18003== HEAP SUMMARY:
==18003==     in use at exit: 551,540 bytes in 3,294 blocks
==18003==   total heap usage: 147,859 allocs, 144,565 frees, 84,461,908
bytes allocated
==18003==
==18003== LEAK SUMMARY:
==18003==    definitely lost: 124,956 bytes in 108 blocks
==18003==    indirectly lost: 32,380 bytes in 54 blocks
==18003==      possibly lost: 0 bytes in 0 blocks
==18003==    still reachable: 394,204 bytes in 3,132 blocks
==18003==         suppressed: 0 bytes in 0 blocks
==18003== Rerun with --leak-check=full to see details of leaked memory
==18003==
==18003== For counts of detected and suppressed errors, rerun with: -v
==18003== Use --track-origins=yes to see where uninitialised values come
from
==18003== ERROR SUMMARY: 142 errors from 32 contexts (suppressed: 2 from 2)
> >> Cheers,
> >>  Dave
> >> On 16 October 2013 16:18, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> >> Dear all,
> >> I'm trying to solve a stokes flow with constant viscosity but with
> non-zero divergence prescribed in the rhs.
> >> I have a matrix created from DMDA (mDa) of 4 dofs: vx, vy, vz and p
> respectively.
> >> I have another DMDA (mDaP) of same size but of 1 dof corresponding to
> only p.
> >> I have assigned the null space for constant pressure inside the code. I
> have assigned two nullspace basis:  One corresponding to vector created
> from mDa that is assigned to outer ksp. Second corresponding to vector
> created from mDaP that is assigned to a ksp obtained from the fieldsplit
> corresponding to the schur complement.
> >> Now when running the code, the solver converges for up to certain size,
> e.g. 92X110 X 92 (the results for this convegent case with -ksp_view is
> given at the end of the emal.
> >> But when I double the size of the grid in each dimension, it gives me a
> run-time error.
> >> The options  I've used are of the kind:
> >> -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_dm_splits
> 0 -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3
> -fieldsplit_0_pc_type hypre -fieldsplit_0_ksp_converged_reason
> -fieldsplit_1_ksp_converged_reason -ksp_converged_reason -ksp_view
> >> Here are:
> >> 1. Error message when using hypre for fieldsplit_0
> >> 2. Error message when using gamg for fieldsplit_0
> >> 3. -ksp_view of the working case using hypre for filedsplit_0
> >> I get following error when I use hypre :
> >> 1.
> >> [5]PETSC ERROR: --------------------- Error Message
> >> [5]PETSC ERROR: Signal received!
> >> [5]PETSC ERROR:
> >> [5]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
> >> [5]PETSC ERROR: See docs/changes/index.html for recent updates.
> >> [5]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> >> [5]PETSC ERROR: See docs/index.html for manual pages.
> >> [5]PETSC ERROR:
> >> [5]PETSC ERROR:
> /epi/asclepios2/bkhanal/works/AdLemModel/build/src/AdLemMain on a
> arch-linux2-cxx-debug named nef001 by bkhanal Wed Oct 16 15:08:42 2013
> >> [5]PETSC ERROR: Libraries linked from
> /epi/asclepios2/bkhanal/petscDebug/lib
> >> [5]PETSC ERROR: Configure run at Wed Oct 16 14:18:48 2013
> >> [5]PETSC ERROR: Configure options
> --with-mpi-dir=/opt/openmpi-gcc/current/ --with-shared-libraries
> --prefix=/epi/asclepios2/bkhanal/petscDebug -download-f-blas-lapack=1
> --download-metis --download-parmetis --download-superlu_dist
> --download-scalapack --download-mumps --download-hypre --with-clanguage=cxx
> >> [5]PETSC ERROR:
> >> [5]PETSC ERROR: User provided function() line 0 in unknown directory
> unknown file
> >> [6]PETSC ERROR:
> >> [6]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or
> the batch system) has told this process to end
> >> [6]PETSC ERROR: Try option -start_in_debugger or
> -on_error_attach_debugger
> >> [6]PETSC ERROR: or see
> http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[6]PETSCERROR: or try
> http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> corruption errors
> >> [6]PETSC ERROR: likely location of problem given in stack below
> >> [6]PETSC ERROR: ---------------------  Stack Frames
> >> [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> >> [6]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >> [6]PETSC ERROR:       is given.
> >> [6]PETSC ERROR: [6] HYPRE_SetupXXX line 130
> /tmp/petsc-3.4.3/src/ksp/pc/impls/hypre/hypre.c
> >> [6]PETSC ERROR: [6] PCSetUp_HYPRE line 94
> >> [6]PETSC ERROR: [6] PCSetUp line 868
> /tmp/petsc-3.4.3/src/ksp/pc/interface/precon.c
> >> [6]PETSC ERROR: [6] KSPSetUp line 192
> /tmp/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
> >> [6]PETSC ERROR: [6] KSPSolve line 356
> >> [6]PETSC ERROR: [6] MatMult_SchurComplement line 75
> /tmp/petsc-3.4.3/src/ksp/ksp/utils/schurm.c
> >> [6]PETSC ERROR: [6] MatNullSpaceTest line 408
> /tmp/petsc-3.4.3/src/mat/interface/matnull.c
> >> [6]PETSC ERROR: [6] solveModel line 113
> "unknowndirectory/"/epi/asclepios2/bkhanal/works/AdLemModel/src/PetscAdLemTaras3D.cxx
> >> 2.
> >> Using gamg instead has errors like following:
> >> [5]PETSC ERROR: ---------------------  Stack Frames
> >> [5]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> available,
> >> [5]PETSC ERROR:       INSTEAD the line number of the start of the
> function
> >> [5]PETSC ERROR:       is given.
> >> [5]PETSC ERROR: [5] PetscLLCondensedAddSorted line 1202
> /tmp/petsc-3.4.3/include/petsc-private/matimpl.h
> >> [5]PETSC ERROR: [5] MatPtAPSymbolic_MPIAIJ_MPIAIJ line 124
> /tmp/petsc-3.4.3/src/mat/impls/aij/mpi/mpiptap.c
> >> [5]PETSC ERROR: [5] MatPtAP_MPIAIJ_MPIAIJ line 80
> >> [5]PETSC ERROR: [5] MatPtAP line 8223
> /tmp/petsc-3.4.3/src/mat/interface/matrix.c
> >> [5]PETSC ERROR: [5] createLevel line 144
> /tmp/petsc-3.4.3/src/ksp/pc/impls/gamg/gamg.c
> >> [5]PETSC ERROR: [5] PCSetUp_GAMG line 545
> >> [5]PETSC ERROR: [5] PCSetUp line 868
> >> [5]PETSC ERROR: [5] KSPSetUp line 192
> >> [5]PETSC ERROR: [5] KSPSolve line 356
> >> [5]PETSC ERROR: [5] MatMult_SchurComplement line 75
> >> [5]PETSC ERROR: [5] MatNullSpaceTest line 408
> >> [5]PETSC ERROR: [5] solveModel line 113
> >> 3.
> >> BUT, It does give me results when I use a domain of size: 91X109 X 91
> (half sized in each dimension) The result along with ksp view in this case
> is as follows:
> >> Linear solve converged due to CONVERGED_RTOL iterations 2
> >> KSP Object: 64 MPI processes
> >>  type: gmres
> >>    GMRES: restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
> >>    GMRES: happy breakdown tolerance 1e-30
> >>  maximum iterations=10000, initial guess is zero
> >>  tolerances:  relative=1e-05, absolute=1e-50, divergence=10000
> >>  left preconditioning
> >>  has attached null space
> >>  using PRECONDITIONED norm type for convergence test
> >> PC Object: 64 MPI processes
> >>  type: fieldsplit
> >>    FieldSplit with Schur preconditioner, blocksize = 4, factorization
> FULL
> >>    Preconditioner for the Schur complement formed from user provided
> matrix
> >>    Split info:
> >>    Split number 0 Fields  0, 1, 2
> >>    Split number 1 Fields  3
> >>    KSP solver for A00 block
> >>      KSP Object:      (fieldsplit_0_)       64 MPI processes
> >>        type: gmres
> >>      PC Object:      (fieldsplit_0_)       64 MPI processes
> >>        type: hypre
> >>          HYPRE BoomerAMG preconditioning
> >>          HYPRE BoomerAMG: Cycle type V
> >>          HYPRE BoomerAMG: Maximum number of levels 25
> >>          HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
> >>          HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
> >>          HYPRE BoomerAMG: Threshold for strong coupling 0.25
> >>          HYPRE BoomerAMG: Interpolation truncation factor 0
> >>          HYPRE BoomerAMG: Interpolation: max elements per row 0
> >>          HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
> >>          HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
> >>          HYPRE BoomerAMG: Maximum row sums 0.9
> >>          HYPRE BoomerAMG: Sweeps down         1
> >>          HYPRE BoomerAMG: Sweeps up           1
> >>          HYPRE BoomerAMG: Sweeps on coarse    1
> >>          HYPRE BoomerAMG: Relax down          symmetric-SOR/Jacobi
> >>          HYPRE BoomerAMG: Relax up            symmetric-SOR/Jacobi
> >>          HYPRE BoomerAMG: Relax on coarse     Gaussian-elimination
> >>          HYPRE BoomerAMG: Relax weight  (all)      1
> >>          HYPRE BoomerAMG: Outer relax weight (all) 1
> >>          HYPRE BoomerAMG: Using CF-relaxation
> >>          HYPRE BoomerAMG: Measure type        local
> >>          HYPRE BoomerAMG: Coarsen type        Falgout
> >>          HYPRE BoomerAMG: Interpolation type  classical
> >>        linear system matrix = precond matrix:
> >>        Matrix Object:         64 MPI processes
> >>          type: mpiaij
> >>          rows=2793120, cols=2793120
> >>          total: nonzeros=221624352, allocated nonzeros=221624352
> >>          total number of mallocs used during MatSetValues calls =0
> >>            using I-node (on process 0) routines: found 14812 nodes,
> limit used is 5
> >>    KSP solver for S = A11 - A10 inv(A00) A01
> >>      KSP Object:      (fieldsplit_1_)       64 MPI processes
> >>        type: gmres
> >>      PC Object:      (fieldsplit_1_)       64 MPI processes
> >>        type: bjacobi
> >>          block Jacobi: number of blocks = 64
> >>          Local solve is same for all blocks, in the following KSP and
> PC objects:
> >>        KSP Object:        (fieldsplit_1_sub_)         1 MPI processes
> >>          type: preonly
> >>          using NONE norm type for convergence test
> >>        PC Object:        (fieldsplit_1_sub_)         1 MPI processes
> >>          type: ilu
> >>            ILU: out-of-place factorization
> >>            0 levels of fill
> >>            tolerance for zero pivot 2.22045e-14
> >>            using diagonal shift on blocks to prevent zero pivot
> [INBLOCKS]
> >>            matrix ordering: natural
> >>            factor fill ratio given 1, needed 1
> >>              Factored matrix follows:
> >>                Matrix Object:                 1 MPI processes
> >>                  type: seqaij
> >>                  rows=14812, cols=14812
> >>                  package used to perform factorization: petsc
> >>                  total: nonzeros=368098, allocated nonzeros=368098
> =0
> >>                    not using I-node routines
> >>            type: seqaij
> >>        linear system matrix followed by preconditioner matrix:
> >>          type: schurcomplement
> >>          rows=931040, cols=931040
> >>            Schur complement A11 - A10 inv(A00) A01
> >>            A11
> >>                type: mpiaij
> >>                total: nonzeros=24624928, allocated nonzeros=24624928
> >>                  not using I-node (on process 0) routines
> >>            A10
> >>                type: mpiaij
> >>                rows=931040, cols=2793120
> >>                total: nonzeros=73874784, allocated nonzeros=73874784
> >>            KSP of A00
> MPI processes
> >>                type: gmres
> Gram-Schmidt Orthogonalization with no iterative refinement
> divergence=10000
> MPI processes
> >>                type: hypre
> hypre call 1
> coarsening 0
> coarsening 1
> >>                  type: mpiaij
> =0
> nodes, limit used is 5
> >>            A01
> >>                type: mpiaij
> >>                rows=2793120, cols=931040
> >>          type: mpiaij
> >>    type: mpiaij
> >>    rows=3724160, cols=3724160, bs=4
> >>    total: nonzeros=393998848, allocated nonzeros=393998848
> >> What could be going wrong here ? Is it something related to null-space
> setting ? But I do not know why it does not arise for smaller domain sizes!
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131016/3b7bed64/attachment-0001.html>
