[petsc-users] Suggestions for code with dof >> 1 ?
Jed Brown
jedbrown at mcs.anl.gov
Wed Oct 16 08:36:49 CDT 2013
Christophe Ortiz <christophe.ortiz at ciemat.es> writes:
> I found where is the problem. I had
> set TSARKIMEXSetFullyImplicit(ts,PETSC_TRUE);
> I found it produces wrong solutions, either with ARKIMEX3, 1BEE or A2.
> Solution becomes negative. Without this option, all ARKIMEX types work very
> well and very fast.
I'm glad they work as IMEX methods (please check that the solutions are
correct), but I would like to find out why they are not working in fully
implicit mode. Is your problem similar to ex25? (If I remember
correctly, that example uses a DAE formulation for boundary conditions
and thus has trouble with some methods with explicit stages. There may
be more going on.)
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131016/ee5041a2/attachment.pgp>
