[petsc-users] ex12 with Neumann BC
    Olivier Bonnefon
    olivier.bonnefon at avignon.inra.fr
    Fri Oct 11 09:01:38 CDT 2013
Hello,
I now able to simulate a two fields non-linear system with fem, and I
get a good speed up with Dirichlet BC. Thanks for your help.
About Neumann BC, I need to add "-ksp_type fgmres", else the line search
failed (even with -snes_mf).
More over, the Neumann version works only in sequential. Indeed, in
parallel, the boundary conditions are applied inside the domain. I guess
it is because the label are automatically add after the mesh
partitioning. This problem doesn't appear in ex12 because there is a
test in the plugin function, but it is not possible to do the same thing
with a complex shape. I don't know what it must be done.
In Neumann case, the 1D-integral apears only in the residual part (ie
the right side hand of the system). Is it done in the
FEMIntegrateBdResidualBatch function ?
Thanks
Olivier B
On 10/10/2013 02:37 AM, Matthew Knepley wrote:
> On Thu, Oct 3, 2013 at 4:48 AM, Olivier Bonnefon
> <olivier.bonnefon at avignon.inra.fr
> <mailto:olivier.bonnefon at avignon.inra.fr>> wrote:
>     Hello,
>     Thank you for your answer, I'm now able to run the ex12.c with
>     Neumann BC (options -bc_type neumann -interpolate 1).
>     I have adapted the ex12.c for the 2D-system:
>     -\Delta u +u =0
>     It consists in adapting the fem->f0Funcs[0] function and adding
>     the jacobian function fem->g0Funcs[0].
>     My implementation works for Dirichlet BC.
>     With Neumann BC(with options -bc_type neumann -interpolate 1), the
>     line search failed. I think my jacobian functions are corrects,
>     because the option "-snes_mf_operator" leads to the same behavior.
> Sorry this took me a long time. Do you mean that it converges with
> -snes_mf?
>     Do you know what I have missed ?
>     In Neumann case, Where is added the 1d-integral along \delta \Omega ?
> You are correct that I am not doing the correct integral for the
> Jacobian. I will put it in soon. That
> is why it should work with the FD approximation since the residual is
> correct.
>   Thanks,
>      Matt
>     Thanks,
>     Olivier Bonnefon
>     On 09/26/2013 06:54 PM, Matthew Knepley wrote:
>>     On Thu, Sep 26, 2013 at 6:04 AM, Olivier Bonnefon
>>         Hello,
>>         I have implemented my own system from ex12.c. It works with
>>         Dirichlet BC, but failed with Neumann one.
>>         So, I'm came back to the example
>>         /src/snes/example/tutorial/ex12.c, and I tried with Neumann BC:
>>         ./ex12 -bc_type NEUMANN
>>     Here is the full list of tests I run (just checked that it passes
>>     in 'next'):
>>     https://bitbucket.org/petsc/petsc/src/f34a81fe8510aa025c9247a5b14f0fe30e3c0bed/config/builder.py?at=master#cl-175
>>     Make sure you use an interpolated mesh with Neumann conditions
>>     since you need faces.
>>        Matt
>>         This leads to the following crach:
>>         [0]PETSC ERROR: --------------------- Error Message
>>         [0]PETSC ERROR: No support for this operation for this object
>>         type!
>>         [0]PETSC ERROR: Unsupported number of vertices 0 in cell 8
>>         for element geometry computation!
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
>>         [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>         [0]PETSC ERROR: See docs/faq.html for hints about trouble
>>         shooting.
>>         [0]PETSC ERROR: See docs/index.html for manual pages.
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: ./ex12 on a arch-linux2-c-debug named
>>         pcbiom38 by olivierb Thu Sep 26 14:53:32 2013
>>         [0]PETSC ERROR: Libraries linked from
>>         /home/olivierb/SOFT/petsc-3.4.2/arch-linux2-c-debug/lib
>>         [0]PETSC ERROR: Configure run at Thu Sep 26 14:44:42 2013
>>         [0]PETSC ERROR: Configure options --with-debugging=1
>>         --download-fiat --download-scientificpython
>>         --download-generator --download-triangle --download-ctetgen
>>         --download-chaco --download-netcdf --download-hdf5
>>         [0]PETSC ERROR:
>>         [0]PETSC ERROR: DMPlexComputeCellGeometry() line 732 in
>>         /home/olivierb/SOFT/petsc-3.4.2/src/dm/impls/plex/plexgeometry.c
>>         [0]PETSC ERROR: DMPlexComputeResidualFEM() line 558 in
>>         /home/olivierb/SOFT/petsc-3.4.2/src/dm/impls/plex/plexfem.c
>>         [0]PETSC ERROR: SNESComputeFunction_DMLocal() line 75 in
>>         /home/olivierb/SOFT/petsc-3.4.2/src/snes/utils/dmlocalsnes.c
>>         [0]PETSC ERROR: SNESComputeFunction() line 1988 in
>>         /home/olivierb/SOFT/petsc-3.4.2/src/snes/interface/snes.c
>>         [0]PETSC ERROR: SNESSolve_NEWTONLS() line 162 in
>>         /home/olivierb/SOFT/petsc-3.4.2/src/snes/impls/ls/ls.c
>>         [0]PETSC ERROR: SNESSolve() line 3636 in
>>         [0]PETSC ERROR: main() line 582 in
>>         "unknowndirectory/"/home/olivierb/solvers/trunk/SandBox/PETSC/LANDSCAPE/REF/ex12.c
>>         MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
>>         with errorcode 56.
>>         NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI
>>         processes.
>>         You may or may not see output from other processes, depending on
>>         exactly when Open MPI kills them.
>>         With Gbd, I saw that DMPlexGetConeSize is 0 for the last point.
>>         Do I have forget a step to use Neumann BC ?
>>         Thanks
>>         Olivier Bonnefon
>>         Olivier Bonnefon
>>         INRA PACA-Avignon, Unité BioSP
>>         Tel: +33 (0)4 32 72 21 58
>>         <tel:%2B33%20%280%294%2032%2072%2021%2058>
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     which their experiments lead.
>>     -- Norbert Wiener
>     Olivier Bonnefon
>     Tel:+33 (0)4 32 72 21 58  <tel:%2B33%20%280%294%2032%2072%2021%2058>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
Olivier Bonnefon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131011/c2fd2e16/attachment.html>
