[petsc-users] Writing a domain decomposition code with PETSc
Fri Oct 11 08:02:37 CDT 2013
On Fri, Oct 11, 2013 at 7:50 AM, Åsmund Ervik <asmund.ervik at ntnu.no> wrote:
> Hi again,
> I am using a 3D DMDA and I want to extract the bounds for the local
> domain. For some reason, DMDAGetGhostCorners gives me the wrong
> numbers. Consider this code:
>     call DMCreateLocalVector(SolScal,Lpressure,ierr)
>     call DMDAVecGetArrayF90(SolScal,Lpressure,array,ierr)
>     tmp=shape(array)
>     call DMDAVecRestoreArrayF90(SolScal,Lpressure,array,ierr)
>     call DMDAGetGhostCorners(SolScal,i,j,k,m,n,p,ierr)
>     write(*,*) tmp(2:)
>     write(*,*) m-i,n-j,p-k
> I.e. I create a local array and inquire about it's shape, and then I
> get info from DMDAGetGhostCorners. So the two last lines should print
> the same, but they don't:
> mpirun -np 2 meph
>           25          26          50
>           25           2          50
>           25          26          50
>           25          26          50
> Note the difference between the first and second lines.
> Am I using DMDAGetGhostCorners wrong here, or what?
Yes. n-j does not mean anything. n is the local size, whereas j is the
global y offset.
   Matt
> Best regards,
> Åsmund Ervik
> On 07. okt. 2013 17:55, Jed Brown wrote:
> > Åsmund Ervik <asmund.ervik at ntnu.no> writes:
> >> Thanks for this comment; I have been suspecting this is a bad
> >> idea, nice to get confirmation. I will follow your advice.
> > Cool.
> >> Other than that, does the mapping from local to global using
> >> Fortran assumed-shape arrays make sense, or is there a better way
> >> of doing it?
> > It looks okay to me.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131011/56606123/attachment.html>
