[petsc-users] SNESSetUp
Matthew Knepley
knepley at gmail.com
Thu Oct 10 12:32:07 CDT 2013
On Thu, Oct 10, 2013 at 12:28 PM, Mark F. Adams <mfadams at lbl.gov> wrote:
>> It seems like first, the (snes->vec_rhs == snes->vec_sol) test should be
>> moved to SNESSolve where these are apparently set.
> This is not good enough since the next lines will fail if snes->vec_sol is
> NULL.
> That's what I suggested below. I can test this now if you like.
Excellent. I just pushed to next.
Matt
> Mark
> I think we do not to substitute vec_func for vec_sol, but
> we also need to move creation of the update vector since it must be the
> size of the solution. Will do it now.
> Matt
>> Second can we use snes->vec_func instead of snes->vec_sol here? This
>> would remove all dependance on vec_rhs and vec_sol in SNESSetup.
>> Mark
>> ! Extract global and local vectors from DM; then duplicate for
>> remaining
>> ! vectors that are the same types
>> call MatGetVecs(solver%KKTmat,solver%xVec2,solver%bVec2,ierr)
>> call VecDuplicate(solver%bVec2,solver%rVec2,ierr)
>> call SNESSetDM(solver%snes,solver%da,ierr)
>> ! call SNESSetApplicationContext(solver%snes,solver,ierr)
>> ! call SNESSetApplicationContext(solver%snes,grid,ierr)
>> ! Set function evaluation routine and vector
>> call SNESSetFunction(solver%snes,solver%rVec2,FormFunction,solver,ierr)
>> call
>> SNESSetJacobian(solver%snes,solver%KKTmat,solver%KKTmat,FormJacobian,solver,ierr)
>> ! Customize nonlinear solver; set runtime options
>> ! Set runtime options (e.g., -snes_monitor -snes_rtol <rtol> -ksp_type
>> <type>)
>> call SNESSetFromOptions(solver%snes,ierr)
>> call SNESSetUp(solver%snes,ierr) ! pre setup, same as (old) KSP
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131010/9137d0cc/attachment.html>
