[petsc-users] Suggestions for code with dof >> 1 ?
Jed Brown
jedbrown at mcs.anl.gov
Thu Oct 10 07:33:18 CDT 2013
Christophe Ortiz <christophe.ortiz at ciemat.es> writes:
> I am facing some problems with this when filling in the Jacobian for a
> problem of 2 diffusion equations (dof=2). See ex25.c.
> If I'm right, then for node i, there should be 3 blocks of 2x2:
> X 0 | Y 0 | X 0
> 0 X | 0 Y | 0 X
> Is it correct ?
> First I tried what you said, to pass a one dimensional array:
> row = i;
> cols[0] = i-1; cols[1] = i; cols[2] = i+1;
> j = 0;
> vallin[j] = X; vallin[j++] = 0;
The expression j++ in vallin[j++] is post-increment, so the two
statements above both write to vallin[0] and vallin[11] is undefined
(whatever garbage was in the array before).
> Then, I tried a 2-dimensional array. I saw in some examples of ts/tutorials
> that it is also possible to pass a multi-dimensional arrays. After all, in
> memory the rows are stored contiguously, so I guess it is equivalent to a
> one-dimensional array.
> j = 0; k = 0;
> valdiff[j][k] = X; valdiff[j][k++] = 0;
Same problem here.
> valdiff[j][k++] = Y; valdiff[j][k++] = 0;
> valdiff[j][k++] = X; valdiff[j][k++] = 0;
> j= 1; k = 0;
> valdiff[j][k] = 0; valdiff[j][k++] = X;
> valdiff[j][k++] = 0; valdiff[j][k++] = Y;
> valdiff[j][k++] = 0; valdiff[j][k++] = X;
> ierr =
> MatSetValuesBlocked(*Jpre,1,&row,3,cols,&valdiff[0][0],INSERT_VALUES);
> I get the same error message.
> What did I do wrong ?
> In ex25.c they use a 3-dimensional array:
> const PetscScalar vals[2][3][2] = {{{dxxL,0},{a *hx+dxx0,0},{dxxR,0}},
> {{0,dxxL},{0,a*hx+dxx0},{0,dxxR}}};
> and &vals[0][0][0] is passed in MatSetValuesBlocked (....,....,
> &vals[0][0][0],...), and it works, though I don't understand how.
That grouping in the 3D array is the same ordering, but (perhaps) makes
it easier to see which expression refers to which entry of the matrix.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131010/7e85c833/attachment.pgp>
