[petsc-users] SNESSetUp
Matthew Knepley
knepley at gmail.com
Wed Oct 9 15:33:02 CDT 2013
On Wed, Oct 9, 2013 at 3:25 PM, Mark F. Adams <mfadams at lbl.gov> wrote:
> I see this in SNESSetUp doc:
> For basic use of the SNES<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNES.html#SNES> solvers
> the user need not explicitly call SNESSetUp<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSetUp.html#SNESSetUp>(),
> since these actions will automatically occur during the call to SNESSolve<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSolve.html#SNESSolve>().
> However, if one wishes to control this phase separately,
> should be called after SNESCreate<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESCreate.html#SNESCreate>()
> and optional routines of the form SNESSetXXX(), but before SNESSolve<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/SNES/SNESSolve.html#SNESSolve>
> I hit this error line in SNESSetUp:
> if (snes->vec_rhs == snes->vec_sol)
> SETERRQ(PETSC_COMM_SELF,PETSC_ERR_ARG_IDN,"Solution vector cannot be right
> hand side vector");
> I put this in a debugger and found that these are both 0 (hence equal).
> It is not obvious what SNESSetXXX I might be missing. I've appended what
> setxxx stuff I'm doing.
> Mark
> ! Set function evaluation routine and vector
> call SNESSetFunction(solver%snes,solver%rVec2,FormFunction,solver,ierr)
> call
> SNESSetJacobian(solver%snes,solver%KKTmat,solver%KKTmat,FormJacobian,solver,ierr)
> ! Customize nonlinear solver; set runtime options
> ! Set runtime options (e.g., -snes_monitor -snes_rtol <rtol> -ksp_type
> <type>)
> call SNESSetFromOptions(solver%snes,ierr)
> call SNESSetUp(solver%snes,ierr) ! pre setup, same as (old) KSP
Your Fortran is hurting my eyes :)
Is solver%rVec2 == 0?
Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131009/8d43e4c0/attachment.html>
