[petsc-users] SlepcInitialize Segmentation Fault
Sonya Blade
sonyablade2010 at hotmail.com
Tue Oct 8 13:39:39 CDT 2013
DEar All,
I'm receiving the segmentation fault during the program run and this happens exactly at the
SlepcInitialize function and I've no idea on what can be wrong, the error messages produced
from compiler is as shown below. Any clue on what is wrong?
ORIGINAL CODE SNIPPET
int main( int argc, char **argv )
Vec v0,vec,vec1,*evec,gamma,vec_test,result_vec; /* initial vector */
Mat B, C, K, M, eigen_mat; /* operator matrix */
EPS eps; /* eigenproblem solver context */
const EPSType type;
PetscInt N,m=15,nev,max_size,row,column,test_int,g_row,g_col;
PetscErrorCode ierr;
PetscScalar eigen_r,eigen_i,test_scalar, *vector_array,*vec1arr;
PetscReal norm;
double value,test;
int i,j, counter, counter2;
FILE *myfile;
SlepcInitialize(&argc,&argv,NULL,NULL);
ERROR MESSAGES
At D:\TEST_FOLDER_asus\PROJECTS\CBFortran\Slepc_C\Slepc_Subspace\main.c:24
Program received signal SIGSEGV, Segmentation fault.
In strncat () (C:\Windows\SysWOW64\msvcrt.dll)
217 /cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/src/sys/objects/options.c: No such file or directory.
#2 0x0065f761 in PetscSetProgramName (name=0x7370652d <Address 0x7370652d out of bounds>) at /cygdrive/d/TEST_FOLDER_asus/petsc-3.4.2/src/sys/objects/options.c:217
Debugger finished with status 0
