[petsc-users] Suggestions for code with dof >> 1 ?
Jed Brown
jedbrown at mcs.anl.gov
Tue Oct 8 09:55:26 CDT 2013
Christophe Ortiz <christophe.ortiz at ciemat.es> writes:
> What are the names of the subroutines to access these options directly
> within the code ? I see there is TSAdaptSetStepLimits but this is to set
> the min and max timestep size.
Sorry, they are not exposed at this time. They can (and should) be
added, but you can also register your own controller. If you'd like to
help out, you can prepare a patch that adds TSAdaptBasicSetClip() and
similar functions to src/ts/adapt/impls/basic/adaptbasic.c.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131008/2d1710c5/attachment.pgp>
