[petsc-users] ex44f.F90 with fortran data types running with 2 cores
Yaakoub El Khamra yye00 at tacc.utexas.edu
Mon Oct 7 12:57:41 CDT 2013
I am going over ex44f.F90 with petsc-3.4.2 built with fortran data types
and compiled with intel compilers. Minor code modifications were made:
type(Vec) as opposed to Vec and so on. I also added CHKERRQ(ierr) wherever
it needed to go and increased the DMDA size (I used 32).
The ierr value at the KSPSolve was 78, and stdout had the error message
below. I must be doing something wrong. Anyone has any thoughts on what
that might be?
[1]PETSC ERROR:
[1]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
probably memory access out of range
[1]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[1]PETSC ERROR: or see
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[1]PETSC ERROR:
or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
corruption errors
[1]PETSC ERROR: PetscMallocValidate: error detected at
 PetscSignalHandlerDefault() line 149 in
/work/02453/saswata/yye00/src/petsc-3.4.2/src/sys/error/signal.c
[1]PETSC ERROR: Memory at address 0x89cfa0 is corrupted
[1]PETSC ERROR: Probably write past beginning or end of array
[1]PETSC ERROR: Last intact block allocated in PetscObjectListAdd() line
119 in /work/02453/saswata/yye00/src/petsc-3.4.2/src/sys/objects/olist.c
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Memory corruption!
[1]PETSC ERROR:  !
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR:
/work/02453/saswata/yye00/src/petsc-3.4.2/src/ksp/ksp/examples/tutorials/ex44f
on a arch-linux2-cxx-debug named c545-501.stampede.tacc.utexas.edu by
saswata Mon Oct  7 12:52:32 2013
[1]PETSC ERROR: Libraries linked from /work/02453/saswata/yye00/lib
[1]PETSC ERROR: Configure run at Mon Oct  7 11:27:02 2013
[1]PETSC ERROR: Configure options --prefix=/work/02453/saswata/yye00/
--with-log=1 --with-info=1 --with-ctable=1 --with-clanguage=C++
--with-fortran-datatypes=1 --with-fortran=1 --with-debugging=1
--with-debugger=1 --with-shared-libraries=1 --with-debugger=gdb
--with-blas-lapack-dir=/opt/apps/intel/13/composer_xe_2013.2.146/mkl/lib/intel64
--with-mpi=1 --with-mpi-compilers=1 --with-x=0 --with-sieve=1
--download-scientificpython --download-fiat --download-generator
--download-triangle --with-ctetgen --download-chaco --download-boost=1
--with-parmetis=1 --download-parmetis=1 --download-fiat=1
--download-scalapack=1 --download-hypre=1 --download-pastix=1
--download-superlu_dist=1 --download-mumps=1 --download-exodusii=1
--download-netcdf=1 --download-hdf5=1 --download-moab=1
--download-umfpack=1 --download-metis --download-ctetgen --download-ptscotch
[1]PETSC ERROR:
[1]PETSC ERROR: PetscMallocValidate() line 137 in
/work/02453/saswata/yye00/src/petsc-3.4.2/src/sys/memory/mtr.c
[1]PETSC ERROR: PetscSignalHandlerDefault() line 149 in
[cli_1]: aborting job:
application called MPI_Abort(MPI_COMM_WORLD, 0) - process 1
^C[c545-501.stampede.tacc.utexas.edu:mpirun_rsh][signal_processor] Caught
signal 2, killing job
TACC: MPI job exited with code: 1
TACC: Shutdown complete. Exiting.
Regards
Yaakoub El Khamra
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131007/f61e63c6/attachment.html>
