[petsc-users] [petsc-dev] mkl-cpardiso configuration
Sun Oct 6 21:12:20 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> If one specifies '--with-mkl=/foo/bar --download-f-blas-lapack' or
> just '--with-mlk=/foo/bar' where configure picks up /usr/lib/libblas.a
> etc - then things will break.
> So somehow these two options should work together - and perhaps the
> way they can do is within blaslapack.py [and not a separate mkl.py]
Note that recent MKL has mkl_link_tool that we should use to avoid
hard-coding the looping strategies needed to link MKL.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131006/d5c3f53d/attachment.pgp>
