[petsc-users] Unable to create >4GB sized HDF5 files on Cray XC30
Juha Jäykkä
juhaj at iki.fi
Sat Oct 5 15:07:38 CDT 2013
> Yes, there will be some extra space, but HDF5 will deal with it.
Splendid.
> > I'll try to get something useful in. What's the timetable?
> Thanks. You're the one that asked to use chunking so it's on your time.
Actually, I didn't ask for it. I only asked for a bug to be fixed. A bug which
means > 4 GB Vec cannot be saved into a HDF5 file using PETSc VecView, because
chunking *was* introduced, but with insane chunk sizes (i.e. the *global*
instead of local Vec size for each chunk).
Anyway, that's just so the record gets set straight: this is NOT a feature
request, this is a bug.
> If other people ask before you put something together, we'll check in
> with you and decide what to do.
Thanks, but no need to: if I'm too slow, I'm happy with someone else's fix. In
fact, I do not have much time to use on this, so I really hope someone else
beats me to it.
But what I really meant by timetable was that when is the next 3.4.x due and
when do you need the fix if it is to go to the next release?
Cheers,
Juha
| Juha Jäykkä, juhaj at iki.fi |
| http://koti.kapsi.fi/~juhaj/ |
