[petsc-users] accessing sequential data (e.g. image) at (i, j, k) in DM in parallel
Bishesh Khanal bisheshkh at gmail.com
Fri Oct 4 07:38:05 CDT 2013
On Fri, Oct 4, 2013 at 1:23 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Oct 4, 2013 at 6:11 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> Dear all,
>> I have a part of a code that does NOT use Petsc, and contains an image K
>> of dimensions mXnXr.
>> It also provides me with a function to access any value at (i,j,k), e.g.
>> using K.getVoxelAt(i,j,k).
>> Now in my petsc code I create a DMDA of size mXnXr to solve a pde. The
>> coefficients of the pde at each grid point should physically correspond to
>> the one in the image K.
>> The usual code I would use to create a matrix from DM is:
>> DMDALocalInfo info;
>> ierr = DMDAGetLocalInfo(da,&info);CHKERRQ(ierr);
>> for (PetscInt k = info.zs; k<info.zs+info.zm; ++k) {
>>         for (PetscInt j = info.ys; j < info.ys+info.ym; ++j) {
>>             for (PetscInt i = info.xs; i < info.xs+info.xm; ++i) {
>> //Here (i,j,k) refers to the indexing/ordering that is internally
>> organized/distributed to different processors.
>> Now, the problem is that I cannot use getVoxel(i,j,k) within the above
>> loop because the ordering and distribution of the image K and the function
>> getVoxel(i,j,k) knows nothing about the "da" I create in my part of the
>> code. K might have been stored by each processor locally. So I believe if I
>> want to use the coefficients from the image K in my code within the above
>> loop, first I need to either:
>> 1) create global vectors from the DMDA and copy all the values of image K
>> to this global vector. Then access the values from this global vector.
>> or
>> 2) find a way to transform (i,j,k) within the above loop to a valid
>> (i,j,k) for the function getVoxel(i,j,k)
>> What should I do to resolve the problem ?
> This explanation is confused. I do not think you mean "global vector", but
> rather you mean the K would be completely held by every process. There
> is only one question here:
>    Is your image K distributed across processes?
No, it is not.
> If so, just match your DA to that distribution. If not, its replicated on
> every process and getVoxel() will work fine.
Yes, thanks it works since K is in every process. Sorry, got confused
(debugging a code for too long makes sometimes people think in weird ways!)
>    Matt
>> Thanks,
>> Bishesh
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131004/576bd877/attachment-0001.html>
