[petsc-users] VecScatter from slice of global vector to sequential vector + AO errors
Randall Mackie
rlmackie862 at gmail.com
Thu Oct 3 14:07:06 CDT 2013
I am trying to create a VecScatter that will scatter all the values from a
horizontal slice of a 3D DMDA global vector (with dof=3) to a sequential
vector on every processor. So far I have been unsuccessful, most likely
because I don't completely understand how to get the appropriate IS to do
this. I believe that you need to create a sequential IS on every processor
that has the PETSc global number for the appropriate values I want to
scatter. What I most recently tried was the following code which takes the
values at level k:
DM :: da3
Vec :: daSlice, daVec
PetscInt :: i, j, k, ierr, nis, istart, istep
IS :: from, to
AO :: ntog
VecScatter :: vscat
PetscInt, allocatable :: indices(:)
! Get the AO context for this DM
call DMDAGetAO(da3,ntog,ierr)
! Create indices for scatter from global vector
allocate (indices(3*nx*ny))
istart=(k-1)*nx*ny*3
nis=nx*ny*3
do i=1,nis
indices(i)=istart+i-1
end do
! Convert the indices from natural ordering to PETSc ordering
call AOApplicationToPetsc(ntog,nis,indices,ierr)
call
ISCreateGeneral(PETSC_COMM_SELF,nis,indices,PETSC_COPY_VALUES,from,ierr)
! Get the index set that specifies elements to scatter to sequential
vector
istep=1
istart=0
nis=3*nx*ny
call ISCreateStride(PETSC_COMM_SELF,nis,istart,istep,to,ierr)
! Create the Vector Scatter to get the values to every processor
call VecScatterCreate(daVec,from,daSlice,to,vscat,ierr)
! Release memory
deallocate (indices)
call AODestroy(ntog,ierr)
call ISDestroy(from,ierr)
call ISDestroy(to,ierr)
This code is throwing errors as follows
[2]PETSC ERROR: --------------------- Error Message
[2]PETSC ERROR: Invalid argument!
[2]PETSC ERROR: Wrong type of object: Parameter # 1!
[2]PETSC ERROR:
[2]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
[2]PETSC ERROR: See docs/changes/index.html for recent updates.
[2]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[2]PETSC ERROR: See docs/index.html for manual pages.
[2]PETSC ERROR:
[2]PETSC ERROR: Libraries linked from
/home/rmackie/PETSc/petsc-3.4.2/linux-gfortran-debug/lib
[2]PETSC ERROR: Configure run at Thu Sep 19 15:08:47 2013
[2]PETSC ERROR: Configure options --with-scalar-type=complex
--with-debugging=1 --with-fortran=1 --download-mpich=1
[2]PETSC ERROR:
[2]PETSC ERROR: AOApplicationToPetsc() line 261 in
/home/rmackie/PETSc/petsc-3.4.2/src/vec/is/ao/interface/ao.c
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Invalid argument!
[0]PETSC ERROR: Wrong type of object: Parameter # 1!
[0]PETSC ERROR:
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Invalid argument!
[1]PETSC ERROR: Wrong type of object: Parameter # 1!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR: Libraries linked from
[1]PETSC ERROR: Configure run at Thu Sep 19 15:08:47 2013
[1]PETSC ERROR: Configure options --with-scalar-type=complex
[1]PETSC ERROR:
[1]PETSC ERROR: AOApplicationToPetsc() line 261 in
[0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: -----------------------------------
etc.
First, I don't see where my error is that is causing these problems, but
second, is there a better way to create this vector scatter without having
to use an AO? I suspect there is, but so far I have been unable to figure
out how to create the correct IS.
Thanks very much,
Randy
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131003/30caf79c/attachment.html>
