[petsc-users] ex12 with Neumann BC
Olivier Bonnefon
olivier.bonnefon at avignon.inra.fr
Thu Oct 3 04:48:13 CDT 2013
Hello,
Thank you for your answer, I'm now able to run the ex12.c with Neumann
BC (options -bc_type neumann -interpolate 1).
I have adapted the ex12.c for the 2D-system:
-\Delta u +u =0
It consists in adapting the fem->f0Funcs[0] function and adding the
jacobian function fem->g0Funcs[0].
My implementation works for Dirichlet BC.
With Neumann BC(with options -bc_type neumann -interpolate 1), the
line search failed. I think my jacobian functions are corrects, because
the option "-snes_mf_operator" leads to the same behavior.
Do you know what I have missed ?
In Neumann case, Where is added the 1d-integral along \delta \Omega ?
Olivier Bonnefon
On 09/26/2013 06:54 PM, Matthew Knepley wrote:
> On Thu, Sep 26, 2013 at 6:04 AM, Olivier Bonnefon
> <olivier.bonnefon at avignon.inra.fr
> <mailto:olivier.bonnefon at avignon.inra.fr>> wrote:
> Hello,
> I have implemented my own system from ex12.c. It works with
> Dirichlet BC, but failed with Neumann one.
> So, I'm came back to the example
> /src/snes/example/tutorial/ex12.c, and I tried with Neumann BC:
> ./ex12 -bc_type NEUMANN
> Here is the full list of tests I run (just checked that it passes in
> 'next'):
> https://bitbucket.org/petsc/petsc/src/f34a81fe8510aa025c9247a5b14f0fe30e3c0bed/config/builder.py?at=master#cl-175
> Make sure you use an interpolated mesh with Neumann conditions since
> you need faces.
> Matt
> This leads to the following crach:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: No support for this operation for this object type!
> [0]PETSC ERROR: Unsupported number of vertices 0 in cell 8 for
> element geometry computation!
> [0]PETSC ERROR:
> [0]PETSC ERROR: Petsc Release Version 3.4.2, Jul, 02, 2013
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR:
> [0]PETSC ERROR: ./ex12 on a arch-linux2-c-debug named pcbiom38 by
> olivierb Thu Sep 26 14:53:32 2013
> [0]PETSC ERROR: Libraries linked from
> /home/olivierb/SOFT/petsc-3.4.2/arch-linux2-c-debug/lib
> [0]PETSC ERROR: Configure run at Thu Sep 26 14:44:42 2013
> [0]PETSC ERROR: Configure options --with-debugging=1
> --download-fiat --download-scientificpython --download-generator
> --download-triangle --download-ctetgen --download-chaco
> --download-netcdf --download-hdf5
> [0]PETSC ERROR:
> [0]PETSC ERROR: DMPlexComputeCellGeometry() line 732 in
> /home/olivierb/SOFT/petsc-3.4.2/src/dm/impls/plex/plexgeometry.c
> [0]PETSC ERROR: DMPlexComputeResidualFEM() line 558 in
> /home/olivierb/SOFT/petsc-3.4.2/src/dm/impls/plex/plexfem.c
> [0]PETSC ERROR: SNESComputeFunction_DMLocal() line 75 in
> /home/olivierb/SOFT/petsc-3.4.2/src/snes/utils/dmlocalsnes.c
> [0]PETSC ERROR: SNESComputeFunction() line 1988 in
> /home/olivierb/SOFT/petsc-3.4.2/src/snes/interface/snes.c
> [0]PETSC ERROR: SNESSolve_NEWTONLS() line 162 in
> /home/olivierb/SOFT/petsc-3.4.2/src/snes/impls/ls/ls.c
> [0]PETSC ERROR: SNESSolve() line 3636 in
> [0]PETSC ERROR: main() line 582 in
> "unknowndirectory/"/home/olivierb/solvers/trunk/SandBox/PETSC/LANDSCAPE/REF/ex12.c
> MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
> with errorcode 56.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> With Gbd, I saw that DMPlexGetConeSize is 0 for the last point.
> Do I have forget a step to use Neumann BC ?
> Thanks
> Olivier Bonnefon
> Olivier Bonnefon
> INRA PACA-Avignon, Unité BioSP
> Tel: +33 (0)4 32 72 21 58 <tel:%2B33%20%280%294%2032%2072%2021%2058>
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
Olivier Bonnefon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131003/9750a2e5/attachment-0001.html>
