[petsc-users] How to speed up geometric multigrid
Michele Rosso
mrosso at uci.edu
Wed Oct 2 17:12:49 CDT 2013
Barry,
sorry for not replying to your other e-mail earlier.
The equation I am solving is:
$\nabla\cdot(\frac{1}{\rho}\nabla p)=\nabla\cdot u^*$
where $p$ is the pressure field, $\rho$ the density field and $u^*$ the
velocity field.
Since I am using finite difference on a staggered grid, the pressure is
defined on "cell" centers, while the velocity components on "cell"
faces, even if
no cell is actually defined.
I am simulating a bi-phase flow, thus both density and pressure are
discontinuos, but not the velocity (no mass trasfer is included at the
moment).
Therefore the right-hand-side (rhs) of the above equation does not have
jumps, while $p$ and $rho$ do.
In order to deal with such jumps, I am using a Ghost Fluid approach.
Therefore the resulting linear system is slighly different from the
typical Poisson system, though
simmetry and diagonal dominance of the matrix are mantained.
The boundary conditions are periodic in all the three space directions,
therefore the system is singular. Thus I removed the nullspace of the
matrix by using:
call MatNullSpaceCreate(
PETSC_COMM_WORLD,PETSC_TRUE,PETSC_NULL_INTEGER,&
& PETSC_NULL_INTEGER,nullspace,ierr)
call KSPSetNullspace(ksp,nullspace,ierr)
call MatNullSpaceDestroy(nullspace,ierr)
Hope this helps. Please let me know if you need any other info.
Also, I use the pressure at the previous time step as starting point for
the solve. Could this be a reason why the convergence is so slow?
Thanks a lot,
Michele
On 10/02/2013 11:39 AM, Barry Smith wrote:
> Something is wrong, you should be getting better convergence. Please answer my other email.
> On Oct 2, 2013, at 1:10 PM, Michele Rosso <mrosso at uci.edu> wrote:
>> Thank you all for your contribution.
>> So far the fastest solution is still the initial one proposed by Jed in an earlier round:
>> -ksp_atol 1e-9 -ksp_monitor_true_residual -ksp_view -log_summary -mg_coarse_pc_factor_mat_solver_package superlu_dist
>> -mg_coarse_pc_type lu -mg_levels_ksp_max_it 3 -mg_levels_ksp_type richardson -options_left -pc_mg_galerkin
>> -pc_mg_levels 5 -pc_mg_log -pc_type mg
>> where I used -mg_levels_ksp_max_it 3 as Barry suggested instead of -mg_levels_ksp_max_it 1.
>> I attached the diagnostics for this case. Any further idea?
>> Thank you,
>> Michele
>> On 10/01/2013 11:44 PM, Barry Smith wrote:
>>> On Oct 2, 2013, at 12:28 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>>>> "Mark F. Adams" <mfadams at lbl.gov> writes:
>>>>> run3.txt uses:
>>>>> -ksp_type richardson
>>>>> This is bad and I doubt anyone recommended it intentionally.
>>> Hell this is normal multigrid without a Krylov accelerator. Under normal circumstances with geometric multigrid this should be fine, often the best choice.
>>>> I would have expected FGMRES, but Barry likes Krylov smoothers and
>>>> Richardson is one of a few methods that can tolerate nonlinear
>>>> preconditioners.
>>>>> You also have, in this file,
>>>>> -mg_levels_ksp_type gmres
>>>>> did you or the recommenders mean
>>>>> -mg_levels_ksp_type richardson ???
>>>>> you are using gmres here, which forces you to use fgmres in the outer solver. This is a safe thing to use you if you apply your BCa symmetrically with a low order discretization then
>>>>> -ksp_type cg
>>>>> -mg_levels_pc_type sor
>>>>> is what I'd recommend.
>>>> I thought that was tried in an earlier round.
>>>> I don't understand why SOR preconditioning in the Krylov smoother is so
>>>> drastically more expensive than BJacobi/ILU and why SOR is called so
>>>> many more times even though the number of outer iterations
>>>> bjacobi: PCApply 322 1.0 4.1021e+01 1.0 6.44e+09 1.0 3.0e+07 1.6e+03 4.5e+04 74 86 98 88 92 28160064317351226 20106
>>>> bjacobi: KSPSolve 46 1.0 4.6268e+01 1.0 7.52e+09 1.0 3.0e+07 1.8e+03 4.8e+04 83100100 99 99 31670065158291309 20800
>>>> sor: PCApply 1132 1.0 1.5532e+02 1.0 2.30e+10 1.0 1.0e+08 1.6e+03 1.6e+05 69 88 99 88 93 21871774317301274 18987
>>>> sor: KSPSolve 201 1.0 1.7101e+02 1.0 2.63e+10 1.0 1.1e+08 1.8e+03 1.7e+05 75100100 99 98 24081775248221352 19652
>> <best.txt>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131002/222b6ae8/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131002/222b6ae8/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131002/222b6ae8/attachment-0001.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131002/222b6ae8/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131002/222b6ae8/attachment-0003.png>
