[petsc-users] Petsc-3.4.2 with MinGW-w64 on Windows 7
Mengda Wu
wumengda at gmail.com
Tue Oct 1 20:05:11 CDT 2013
Hi Satish,
Thanks a lot for your reply!
Is there a way to use the mingw64 which is not shipped with cygwin? For
example, use windows native paths when testing the compiler.
Mengda
On Tue, Oct 1, 2013 at 5:55 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> Looks like this mingw install is not from cygwin - and does not work with
> cygwin paths.
> Suggest using mingw from cygwin - or install and use cygwin64 [which has
> non-mingw gcc-64]
> You might need the following patch
> https://bitbucket.org/petsc/petsc/commits/e4773d96ef73f1e0b315c5b0194cae499d71e207
> Satish
> On Tue, 1 Oct 2013, Mengda Wu wrote:
> > Hello all,
> > I am trying to compile 64 bit version of petsc-3.4.2 using MinGW-w64
> > (latest version 4.8.1 installed with
> http://sourceforge.net/projects/mingwbuilds/files/mingw-builds-install/mingw-builds-install.exe/download
> > on Windows 7 64 bit. I have cygwin, python (under cygwin) installed.
> > I run the "$ ./config/configure.py --with-cc='gcc' --with-fc='gfortran'
> > --with-cxx='g++'
> > --with-clanguage=cxx --with-mpi=0 --with-debugging=0 --with-sowing=0
> > --with-c
> > 2html=0". I got some errors in checkCCompiler. The log file is as
> follows:
> > TEST checkCCompiler from
> config.setCompilers(/cygdrive/c/Library/PETSc/download/petsc-3.4.2/config/BuildSystem/config/setCompilers.py:525)
> > TESTING: checkCCompiler from
> > config.setCompilers(config/BuildSystem/config/setCompilers.py:525)
> > Locate a functional C compiler
> > Checking for program /home/glxiong/bin/gcc...not found
> > Checking for program /usr/local/bin/gcc...not found
> > Checking for program /usr/bin/gcc...not found
> > /cygdrive/c/Library/MinGW/x64-4.8.1/mingw64/bin/gcc...found
> > Defined make macro "CC" to "gcc"
> > Pushing language C
> > All intermediate test results are stored in
> > /tmp/petsc-novY5r/config.setCompilers
> > sh: gcc -c -o /tmp/petsc-novY5r/config.setCompilers/conftest.o
> > -I/tmp/petsc-novY5r/config.setCompilers
> > /tmp/petsc-novY5r/config.setCompilers/conftest.c
> > Executing: gcc -c -o /tmp/petsc-novY5r/config.setCompilers/conftest.o
> > sh:
> > Possible ERROR while running compiler: ret = 256
> > error message = {gcc.exe: error:
> > /tmp/petsc-novY5r/config.setCompilers/conftest.c: No such file or
> directory
> > gcc.exe: fatal error: no input files
> > compilation terminated.
> > I think the problem is the MinGW-w64 compiler does not recognize the
> cygwin
> > path like /tmp. Is there a workaround? I tried to use a native Windows
> > python, but the configure fails to find the "make" command then. I guess
> > MinGW may be not supported by PetSc yet.
> > However, I found someone has successfully compiled a MPI-version Petsc on
> > Windows 64 bit. Here is the link:
> > http://geuz.org/pipermail/gmsh/2012/007589.html.
> > How is that possible?
> > Thanks,
> > Mengda
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131001/4f830a10/attachment-0001.html>
