[petsc-users] Back to struct in Fortran to represent field with dof > 1
Tue Oct 1 07:01:02 CDT 2013
Barry Smith <bsmith at mcs.anl.gov> writes:
>    I put the example with VecGetArray() into petsc-dev and if you send
>    me one with DMDAVecGetArray() I'll add that as well.  Since the
>    derived type has to appear explicitly in the code I can't put
>    something in the library only in examples that people can copy and
>    change.
This is the sad state of Fortran.  Alternatively, it should be possible
to call the C DMDAVecGetArray via the ISO C bindings in Fortran 2003.
Yet another example that the best way to call Fortran libraries from
Fortran is to use the ISO C bindings.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131001/075ae953/attachment.pgp>
