[petsc-users] fieldsplit: Unhandled case, must have at least two fields, not 1!
Jed Brown
jedbrown at mcs.anl.gov
Sat Nov 30 17:33:19 CST 2013
Mark Adams <mfadams at lbl.gov> writes:
> I tried putting what I thought was the problem in ex54 and you are correct
> it did not cause a problem.
Okay.
> I've attached a good and bad "petsc.rc" file from my app and an output file
> with this error. Perhaps you can see how this broke.
I don't have your app so I don't know what that code looks like. The
two options files are very different. Presumably you can run on one
process and use a debugger to see what happens in
PCFieldSplitSetDefaults. If you think PETSc is mishandling this, please
add a test to PETSc (perhaps a small addition to an existing test) to
demonstrate the issue.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131130/fb44e030/attachment.pgp>
