[petsc-users] Inhomogeneous laplacian
Jed Brown
jedbrown at mcs.anl.gov
Fri Nov 29 12:43:04 CST 2013
"iwaddington ." <iwaddington at gmail.com> writes:
> Thanks Jed, so if I understood correctly in fact there is nothing to be
> done, since I was already recomputing the staggered values when passing
> from one node to its neighbour.
I think if you benchmark and don't do something spuriously wasteful,
you'll find that computing the averages is not really a bottleneck.
What happens if you replace the harmonic average with an arithmetic
average (trivially cheap)? If that's a bottleneck, you can
unroll-and-jam your stencil operation and vectorize the division.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131129/cdc4163c/attachment.pgp>
