[petsc-users] Inhomogeneous laplacian
iwaddington . iwaddington at gmail.com
Fri Nov 29 12:13:18 CST 2013
Hi, I am trying to optimize a code that solves an inhomogeneous laplacian
pde of the form :
       -div ( K(x) grad(u) ) = f           0 < x,y < 1     where K(x) is a
matrix  that
depends   on the position
 I use finite differences and the values of "f" and "u" are cell centered.
 The problem is the following, since each interface is common to two cells,
and I need the value of K on the interfaces, which is taken as an harmonic
mean, I would like to compute these values only once, and then pass them as
some user context to KSPSetComputeOperators, because I am using a dmda. Any
ideas ?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131129/4124f21d/attachment.html>
