[petsc-users] Floating point exception, only occurs when assembling "large" matrices
Justin Dong (Me) jsd1 at rice.edu
Wed Nov 27 03:19:41 CST 2013
Hi Karl,
Unfortunately, I don’t have access to valgrind as I’m on Mac OS X 10.9 right now. I’m only examining the global mass matrix right now, which will be block diagonal in 3x3 blocks if I’m not mistaken. The larger application is for DG FEM, which definitely has a different non-zero pattern and more than 3 non-zero entries per row. For the global matrix overall, my allocation of the non-zero entries per rough is just a rough estimate. As I understand it, I don’t have to be exact when specifying this number to MatCreateSeqAIJ.
Attached below is a minimal code that should run and produce the problem. I hope it will compile for you. I added comments where necessary. The variable ‘refs’ in main controls the mesh, and on my machine it works up to and including refs=5. For refs=6 is where I get the errors. It’s a bit lengthy but oh well.
Type: application/zip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131127/7ffde7be/attachment-0001.zip>
On Nov 27, 2013, at 3:22 AM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi Justin,
> did you run your code through Valgrind? I suspect that this is caused by some memory corruption, particularly as you claim that smaller matrix sizes are fine. Also, do you check all the error codes returned by PETSc routines?
> Also, are you sure about the nonzeropattern of your matrix? From your description it sounds like you are solving 8192 decoupled problems of size 3x3, while for e.g. typical finite element applications you get 3x3 local mass matrices per cell, with the total number of degrees of freedom given by the number of vertices.
> If the above doesn't help: Any chance of sending us the relevant source code?
> Best regards,
> Karli
> On 11/27/2013 09:12 AM, Justin Dong (Me) wrote:
>> I am assembling a global mass matrix on a mesh consisting of 8192
>> elements and 3 basis functions per element (so the global dimension is
>> 24,576. For some reason, when assembling this matrix I get tons of
>> floating point exceptions everywhere:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Floating point exception!
>> [0]PETSC ERROR: Inserting nan at matrix entry (0,0)!
>> I get this error for every 3rd diagonal entry of the matrix, but the
>> problem is bigger than that I suspect. In my computation of the local
>> 3x3 element mass matrices, printing out the values gives all zeros
>> (which is what the entries are initialized to be in my code).
>> I’m at a loss for how to debug this problem. My first thought was that
>> there is an error in the mesh, but I’m certain now that this is not the
>> case since the mesh is generated using the exact same routine that
>> generates all of my coarser meshes before this one that fails. For
>> example, the mesh that is one refinement level below this one has 2048
>> elements and works completely fine. This is how I am creating the global
>> matrix:
>> MatCreateSeqAIJ(PETSC_COMM_SELF, NLoc*nElems, NLoc*nElems, NLoc,
>>    PETSC_NULL, &Mglobal);
>> where I allocate NLoc = 3 non-zero entries per row in this case.
