[petsc-users] subksp type of PCGASM
Dmitry Karpeyev
karpeev at mcs.anl.gov
Tue Nov 26 12:33:17 CST 2013
Thanks for reporting this.
There appears to be a bug in MatGetSubMatricesParallel().
I'll look into it and add a test for the case above.
In the meantime, maybe you could tell me more about what you are trying
to do? PCGASM: it is rather experimental and doesn't get much use
ordinarily.
Depending on your particular use case, we can either try improving PCGASM,
or find a different way to accomplish the same thing.
Thanks.
Dmitry.
On Mon, Nov 25, 2013 at 9:07 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Laurent Berenguer <laurent.berenguer at gmail.com> writes:
> >>How exactly did you set this subksp? Did you modify the code or change
> >>the command line arguments? Did the test run without errors when you
> >>don't modify anything?
> > I tried both methods, the error is the same in both cases :
> > - I added the option -user_set_subdomain_solvers and modified the code
> > from
> > ierr = PCSetType(subpc,PCILU);CHKERRQ(ierr);
> > to
> > ierr = PCSetType(subpc,PCJACOBI);CHKERRQ(ierr);
> > - Or I only added -sub_ksp_type gmres without changing the code.
> > The example runs correctly when I change nothing. But I'm not sure
> > what is the default subksp. When I change nothing in the code but it
> > seems to be KSPPREONLY.
> It should say if you run with -ksp_view.
> PCGASM is Dmitry's project and I don't think it has gotten much use yet.
> I'll leave it to him to explain what's going on here. If your cases are
> supposed to work, they should be added as tests.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131126/8076c6f5/attachment.html>
