[petsc-users] tmpdir: change the path of temporary directory created during installation
Tue Nov 26 11:57:03 CST 2013
On Tue, Nov 26, 2013 at 11:53 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Xiangdong <epscodes at gmail.com> writes:
> > By the way, how can I find a list of all the environment variables that
> > petsc takes? Thanks.
> This is not a PETSc thing, it's POSIX mkstemp/mkdtemp.
We use two env vars to indicate the build:
  PETSC_DIR      = Root of the source tree
  PETSC_ARCH = Label for the build (has default if not defined)
We use one env var to input options for a run:
  PETSC_OPTIONS = <command line options>
    Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131126/4ee44c2e/attachment-0001.html>
