[petsc-users] PetscDrawSetSave
Mon Nov 25 11:38:00 CST 2013
On Nov 25, 2013, at 9:21 AM, iwaddington . <iwaddington at gmail.com> wrote:
> Thanks Barry, so I just have to download the 3 files you changed and run the configure and make steps again am I right ?
  You can do that but it would be better to use git to access the repository, instructions are in the wiki I sent you.
   The reason to use git to access the repository is because it is then trivial to access new changes and improvements in the future. If you always try to do it by downloading individual files you will find it is cumbersome and prone to error.
   Barry
> On Mon, Nov 25, 2013 at 2:27 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    We didn’t have support for saving these. I have just added it. You can access it in the “next” branch of the PETSc repository, see https://bitbucket.org/petsc/petsc/wiki/Home
> Run the code with -draw_save -popup_draw_save  (I had named those extra windows popup windows)
> Please let us know if this does not work.
>    Barry
> On Nov 24, 2013, at 8:47 PM, iwaddington . <iwaddington at gmail.com> wrote:
> > Hi, I am using PetscDrawSetSave to save some contour plots in gif files, but it is not saving the contour scales along with the images. Do you know a way to save the contour scales along with the plots ? Thanks.
