[petsc-users] neumann failure in my version of snes ex12
Geoffrey Irving irving at naml.us
Sun Nov 24 18:35:23 CST 2013
On Sun, Nov 24, 2013 at 4:27 PM, Geoffrey Irving <irving at naml.us> wrote:
> On Sun, Nov 24, 2013 at 4:21 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Sun, Nov 24, 2013 at 6:18 PM, Geoffrey Irving <irving at naml.us> wrote:
>>> On Sun, Nov 24, 2013 at 4:10 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>> > On Sun, Nov 24, 2013 at 6:06 PM, Geoffrey Irving <irving at naml.us> wrote:
>>> >> On Sun, Nov 24, 2013 at 5:41 AM, Matthew Knepley <knepley at gmail.com>
>>> >> wrote:
>>> >> > On Sat, Nov 23, 2013 at 5:44 PM, Geoffrey Irving <irving at naml.us>
>>> >> > wrote:
>>> >> >> On Sat, Nov 23, 2013 at 12:20 PM, Matthew Knepley
>>> >> >> wrote:
>>> >> >> > On Sat, Nov 23, 2013 at 2:04 PM, Geoffrey Irving <irving at naml.us>
>>> >> >> > wrote:
>>> >> >> >> On Sat, Nov 23, 2013 at 10:11 AM, Matthew Knepley
>>> >> >> >> wrote:
>>> >> >> >> > On Sat, Nov 23, 2013 at 12:07 PM, Geoffrey Irving
>>> >> >> >> > <irving at naml.us>
>>> >> >> >> > wrote:
>>> >> >> >> >> On Sat, Nov 23, 2013 at 4:43 AM, Matthew Knepley
>>> >> >> >> >> wrote:
>>> >> >> >> >> > On Fri, Nov 22, 2013 at 6:42 PM, Geoffrey Irving
>>> >> >> >> >> > <irving at naml.us>
>>> >> >> >> >> > wrote:
>>> >> >> >> >> >> On Fri, Nov 22, 2013 at 4:25 PM, Matthew Knepley
>>> >> >> >> >> >> wrote:
>>> >> >> >> >> >> > On Fri, Nov 22, 2013 at 6:09 PM, Geoffrey Irving
>>> >> >> >> >> >> > <irving at naml.us>
>>> >> >> >> >> >> > wrote:
>>> >> >> >> >> >> >> On Fri, Nov 22, 2013 at 3:41 PM, Matthew Knepley
>>> >> >> >> >> >> >> wrote:
>>> >> >> >> >> >> >> > On Fri, Nov 22, 2013 at 5:36 PM, Geoffrey Irving
>>> >> >> >> >> >> >> > <irving at naml.us>
>>> >> >> >> >> >> >> > wrote:
>>> >> >> >> >> >> >> >> I have a duplicate of snes ex12 (FEM Poisson) which
>>> >> >> >> >> >> >> >> works
>>> >> >> >> >> >> >> >> with
>>> >> >> >> >> >> >> >> Dirichlet boundary conditions, but it's breaking for
>>> >> >> >> >> >> >> >> me
>>> >> >> >> >> >> >> >> with
>>> >> >> >> >> >> >> >> Neumann
>>> >> >> >> >> >> >> >> conditions.  In particular, with Neumann conditions I
>>> >> >> >> >> >> >> >> get
>>> >> >> >> >> >> >> >> results
>>> >> >> >> >> >> >> >> which explode even though I believe I am setting a
>>> >> >> >> >> >> >> >> constant
>>> >> >> >> >> >> >> >> nullspace.
>>> >> >> >> >> >> >> >> For example, if I use two first order elements (the
>>> >> >> >> >> >> >> >> unit
>>> >> >> >> >> >> >> >> square
>>> >> >> >> >> >> >> >> divided into two triangles), the resulting solution
>>> >> >> >> >> >> >> >> has
>>> >> >> >> >> >> >> >>     L2 error = 1.75514e+08
>>> >> >> >> >> >> >> >>     u = [-175513825.75680602, -175513825.66302037,
>>> >> >> >> >> >> >> >> -175513825.48390722, -175513824.84436429]
>>> >> >> >> >> >> >> >> This looks rather a lot like the null space isn't
>>> >> >> >> >> >> >> >> getting
>>> >> >> >> >> >> >> >> through.
>>> >> >> >> >> >> >> >> I
>>> >> >> >> >> >> >> >> am creating the constant nullspace with
>>> >> >> >> >> >> >> >>       MatNullSpace null;
>>> >> >> >> >> >> >> >> CHECK(MatNullSpaceCreate(comm(),PETSC_TRUE,0,0,&null));
>>> >> >> >> >> >> >> >>       CHECK(MatSetNullSpace(m,null));
>>> >> >> >> >> >> >> >>       CHECK(MatNullSpaceDestroy(&null));
>>> >> >> >> >> >> >> >> If I pass "-ksp_view -mat_view", I get the following.
>>> >> >> >> >> >> >> >> The
>>> >> >> >> >> >> >> >> matrix
>>> >> >> >> >> >> >> >> entries seem right (they do indeed have the constant
>>> >> >> >> >> >> >> >> nullspace),
>>> >> >> >> >> >> >> >> and
>>> >> >> >> >> >> >> >> ksp_view shows that a nullspace is attached.  Is
>>> >> >> >> >> >> >> >> attaching
>>> >> >> >> >> >> >> >> the
>>> >> >> >> >> >> >> >> nullspace to the matrix with MatSetNullSpace enough,
>>> >> >> >> >> >> >> >> or
>>> >> >> >> >> >> >> >> do
>>> >> >> >> >> >> >> >> I
>>> >> >> >> >> >> >> >> need
>>> >> >> >> >> >> >> >> to
>>> >> >> >> >> >> >> >> additionally attach it to the KSP object?
>>> >> >> >> >> >> >> > 1) I always run with -ksp_monitor_true_residual now
>>> >> >> >> >> >> >> > when
>>> >> >> >> >> >> >> > debugging.
>>> >> >> >> >> >> >> > This
>>> >> >> >> >> >> >> > can
>>> >> >> >> >> >> >> > give
>>> >> >> >> >> >> >> >     you an idea whether you have a singular PC, which
>>> >> >> >> >> >> >> > I
>>> >> >> >> >> >> >> > suspect
>>> >> >> >> >> >> >> > here.
>>> >> >> >> >> >> >> > 2) Can you try using -pc_type jacobi? I think ILU
>>> >> >> >> >> >> >> > might
>>> >> >> >> >> >> >> > go
>>> >> >> >> >> >> >> > crazy
>>> >> >> >> >> >> >> > on a
>>> >> >> >> >> >> >> > deficient matrix.
>>> >> >> >> >> >> >> Here are results with -ksp_monitor_true_residual
>>> >> >> >> >> >> >> -pc_type
>>> >> >> >> >> >> >> none:
>>> >> >> >> >> >> >>     http://naml.us/random/laplace-rtol.txt # with
>>> >> >> >> >> >> >> -ksp_rtol
>>> >> >> >> >> >> >> 1e-5
>>> >> >> >> >> >> >>     http://naml.us/random/laplace-atol.txt # with
>>> >> >> >> >> >> >> -ksp_atol
>>> >> >> >> >> >> >> 1e-5
>>> >> >> >> >> >> > Okay, if you have an inconsistent RHS I do not think that
>>> >> >> >> >> >> > true_residual
>>> >> >> >> >> >> > will work
>>> >> >> >> >> >> > since it uses the unprojected b, but the solve should be
>>> >> >> >> >> >> > fine.
>>> >> >> >> >> >> I still don't understand why the atol version is able to
>>> >> >> >> >> >> drift
>>> >> >> >> >> >> so
>>> >> >> >> >> >> far
>>> >> >> >> >> >> away from zero mean, even after tens of thousands of
>>> >> >> >> >> >> iterations.
>>> >> >> >> >> >> If
>>> >> >> >> >> >> KSP sees a null space on the matrix, shouldn't it project
>>> >> >> >> >> >> that
>>> >> >> >> >> >> null
>>> >> >> >> >> >> space out of the *linear system* residual and also out of
>>> >> >> >> >> >> solution
>>> >> >> >> >> >> on
>>> >> >> >> >> >> each iteration?  Even if it is only projecting out of the
>>> >> >> >> >> >> solution
>>> >> >> >> >> >> delta, how can null space errors be accumulating?
>>> >> >> >> >> > Both the KSP and Mat show that the null space is set, so
>>> >> >> >> >> > everything
>>> >> >> >> >> > should
>>> >> >> >> >> > work fine,
>>> >> >> >> >> > and at this point its no longer DMPlex that is in control,
>>> >> >> >> >> > its
>>> >> >> >> >> > standard
>>> >> >> >> >> > PETSc.
>>> >> >> >> >> > We have reached the limit of usefu talking. Something is
>>> >> >> >> >> > obviously
>>> >> >> >> >> > wrong
>>> >> >> >> >> > with the code,
>>> >> >> >> >> > but since this routinely works in PETSc examples. In
>>> >> >> >> >> > situations
>>> >> >> >> >> > like
>>> >> >> >> >> > these I think we need
>>> >> >> >> >> > to follow the execution in the debugger to see what is
>>> >> >> >> >> > wrong..You
>>> >> >> >> >> > can
>>> >> >> >> >> > look at Vec values
>>> >> >> >> >> > in the debugger using
>>> >> >> >> >> >   (gdb) p ((Vec_Seq*) b-.data)->array[0]@v->map.n
>>> >> >> >> >> > and I look at DMPlex things with
>>> >> >> >> >> >   (gdb) p ((DM_Plex*) dm->data)->coneSection
>>> >> >> >> >> > etc.
>>> >> >> >> >> Thanks, I appreciate the help.  It looks like there were at
>>> >> >> >> >> least
>>> >> >> >> >> two
>>> >> >> >> >> different problems:
>>> >> >> >> >> 1. The boundary FE I was creating had the same dimension as
>>> >> >> >> >> the
>>> >> >> >> >> interior FE (instead of codimension 1), due to misreading ex12
>>> >> >> >> >> even
>>> >> >> >> >> though I had correctly refactored it.  I added a dimension
>>> >> >> >> >> consistency
>>> >> >> >> >> check to my code, but I can do this in
>>> >> >> >> >> DMPlexComputeResidualFEM
>>> >> >> >> >> as
>>> >> >> >> >> well to catch future user errors.
>>> >> >> >> >> 2. Even after fixing the dimensions, my boundary functions in
>>> >> >> >> >> PetscFEM
>>> >> >> >> >> are getting x values both inside and completely outside the
>>> >> >> >> >> domain.
>>> >> >> >> >> Almost certainly more user error, but hopefully also something
>>> >> >> >> >> I
>>> >> >> >> >> can
>>> >> >> >> >> add a check for in petsc once I localize it.
>>> >> >> >> > This could be my bug. The test I have for ex12 is the variable
>>> >> >> >> > coefficient problem
>>> >> >> >> > with div (x + y) grad u = f. This seems to check between the
>>> >> >> >> > analytic
>>> >> >> >> > and field
>>> >> >> >> > versions, meaning that the x coming into f1() matches the x I
>>> >> >> >> > used
>>> >> >> >> > to
>>> >> >> >> > make the
>>> >> >> >> > field, and my exact solution.
>>> >> >> >> It does seem to happen with stock snes ex12:
>>> >> >> >>     branch: irving/assert-ex12-in-box1
>>> >> >> >>     % mpiexec -host localhost -n 1
>>> >> >> >> /home/irving/petsc/debug/lib/ex12-obj/ex12 -run_type test
>>> >> >> >> -refinement_limit 0.0    -bc_type neumann   -interpolate 1
>>> >> >> >> -petscspace_order 1 -bd_petscspace_order 1 -show_initial
>>> >> >> >> -dm_plex_print_fem 1 -dm_view ::ascii_info_detail
>>> >> >> >>     [0]PETSC ERROR: evaluation at point outside unit box: 0 1.25
>>> >> >> >> I'll trace down why this is happening.
>>> >> >> > My first guess is a triangle with backwards edge. This could cause
>>> >> >> > the
>>> >> >> > geometry routines to barf.
>>> >> >> I don't think it's edge orientation: it breaks (though at different
>>> >> >> points) regardless of whether I orient all the edges clockwise or
>>> >> >> counterclockwise.  Also, I would expect bad edge orientation to
>>> >> >> result
>>> >> >> in bad normals but not to produce bad quadrature locations (nor bad
>>> >> >> residuals as long as the user routines don't depend on normal).
>>> >> >> Specifically, I think the problem is a sign error in
>>> >> >> DMPlexComputeProjection2Dto1D_Internal.  The following patch seems
>>> >> >> to
>>> >> >> fix the out of bounds evaluation problem.
>>> >> >> DMPlexComputeProjection2Dto1D is computing a matrix which maps from
>>> >> >> the given segment to the canonical segment, and
>>> >> >> DMPlexComputeLineGeometry_Internal expects a map from the canonical
>>> >> >> segment to the given segment.
>>> >> >> snes ex12 passes with and without this change, presumably because
>>> >> >> the
>>> >> >> only Neumann test has constants along each box side, and is
>>> >> >> therefore
>>> >> >> invariant to this error.
>>> >> > When I replaced my kludge with code using the normal explicitly, I
>>> >> > get
>>> >> > the
>>> >> > same
>>> >> > error as you do. You fix is correct, and I checked it into
>>> >> > knepley/fix-fem-bd-integrate
>>> >> > https://bitbucket.org/petsc/petsc/branch/knepley/fix-fem-bd-integrate
>>> >> > along with other fixes that I think get Neumann all the way correct
>>> >> > in
>>> >> > ex12.
>>> >> >> Unfortunately, my Laplace test is also invariant to this error, so
>>> >> >> this bug is unrelated to the earlier problem.
>>> >> > It could be one of the other fixes I made. Could you run again?
>>> >> Much better.  All the points and (inward) normals are right, and now
>>> >> my residuals have zero sum as expected.  There's still something
>>> >> wrong, since I don't get the exact solution with second order
>>> >> elements, but that's probably an independent problem.  I will trace it
>>> >> down.  Thanks for the help and fixes!
>>> >> Why did you choose inward pointing normals, by the way?  I would have
>>> >> though outward pointing normals are the nearly universal convention.
>>> > That is a bug fixed in that branch. Did you try next?
>>> Oops, I had misread that commit message as "Use inward pointing
>>> normal" rather than "Used inward pointing normal".  I get outward
>>> normals if I reorient the outer boundary edges in my DMPlex to be
>>> clockwise, which I guess is what you intended.
>>> Closer and closer!
>> Hmm, no. I use counter-clockwise ordering too. Now I do not understand what
>> is going on. Something is wrong.
> Closer look coming up.  I could easily be wrong.  I hate arithmetic in Z_2.
Sorry for the noise: everything is inconsistent, I'd just forgotten
that boundary halfedges in a corner mesh are counterclockwise around
the *outside*, not the inside.  I get outward pointing normals if my
DMPlex has counterclockwise boundary edges.
Geoffrey
