[petsc-users] neumann failure in my version of snes ex12
Geoffrey Irving irving at naml.us
Sat Nov 23 12:07:57 CST 2013
On Sat, Nov 23, 2013 at 4:43 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Nov 22, 2013 at 6:42 PM, Geoffrey Irving <irving at naml.us> wrote:
>> On Fri, Nov 22, 2013 at 4:25 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > On Fri, Nov 22, 2013 at 6:09 PM, Geoffrey Irving <irving at naml.us> wrote:
>> >> On Fri, Nov 22, 2013 at 3:41 PM, Matthew Knepley <knepley at gmail.com>
>> >> wrote:
>> >> > On Fri, Nov 22, 2013 at 5:36 PM, Geoffrey Irving <irving at naml.us>
>> >> > wrote:
>> >> >> I have a duplicate of snes ex12 (FEM Poisson) which works with
>> >> >> Dirichlet boundary conditions, but it's breaking for me with Neumann
>> >> >> conditions.  In particular, with Neumann conditions I get results
>> >> >> which explode even though I believe I am setting a constant
>> >> >> nullspace.
>> >> >> For example, if I use two first order elements (the unit square
>> >> >> divided into two triangles), the resulting solution has
>> >> >>     L2 error = 1.75514e+08
>> >> >>     u = [-175513825.75680602, -175513825.66302037,
>> >> >> -175513825.48390722, -175513824.84436429]
>> >> >> This looks rather a lot like the null space isn't getting through.
>> >> >> I
>> >> >> am creating the constant nullspace with
>> >> >>       MatNullSpace null;
>> >> >>       CHECK(MatNullSpaceCreate(comm(),PETSC_TRUE,0,0,&null));
>> >> >>       CHECK(MatSetNullSpace(m,null));
>> >> >>       CHECK(MatNullSpaceDestroy(&null));
>> >> >> If I pass "-ksp_view -mat_view", I get the following.  The matrix
>> >> >> entries seem right (they do indeed have the constant nullspace), and
>> >> >> ksp_view shows that a nullspace is attached.  Is attaching the
>> >> >> nullspace to the matrix with MatSetNullSpace enough, or do I need to
>> >> >> additionally attach it to the KSP object?
>> >> > 1) I always run with -ksp_monitor_true_residual now when debugging.
>> >> > This
>> >> > can
>> >> > give
>> >> >     you an idea whether you have a singular PC, which I suspect here.
>> >> > 2) Can you try using -pc_type jacobi? I think ILU might go crazy on a
>> >> > deficient matrix.
>> >> Here are results with -ksp_monitor_true_residual -pc_type none:
>> >>     http://naml.us/random/laplace-rtol.txt # with -ksp_rtol 1e-5
>> >>     http://naml.us/random/laplace-atol.txt # with -ksp_atol 1e-5
>> > Okay, if you have an inconsistent RHS I do not think that true_residual
>> > will work
>> > since it uses the unprojected b, but the solve should be fine.
>> I still don't understand why the atol version is able to drift so far
>> away from zero mean, even after tens of thousands of iterations.  If
>> KSP sees a null space on the matrix, shouldn't it project that null
>> space out of the *linear system* residual and also out of solution on
>> each iteration?  Even if it is only projecting out of the solution
>> delta, how can null space errors be accumulating?
> Both the KSP and Mat show that the null space is set, so everything should
> work fine,
> and at this point its no longer DMPlex that is in control, its standard
> PETSc.
> We have reached the limit of usefu talking. Something is obviously wrong with the code,
> but since this routinely works in PETSc examples. In situations like these I think we need
> to follow the execution in the debugger to see what is wrong..You can look at Vec values
> in the debugger using
>   (gdb) p ((Vec_Seq*) b-.data)->array[0]@v->map.n
> and I look at DMPlex things with
>   (gdb) p ((DM_Plex*) dm->data)->coneSection
> etc.
Thanks, I appreciate the help.  It looks like there were at least two
different problems:
1. The boundary FE I was creating had the same dimension as the
interior FE (instead of codimension 1), due to misreading ex12 even
though I had correctly refactored it.  I added a dimension consistency
check to my code, but I can do this in DMPlexComputeResidualFEM as
well to catch future user errors.
2. Even after fixing the dimensions, my boundary functions in PetscFEM
are getting x values both inside and completely outside the domain.
Almost certainly more user error, but hopefully also something I can
add a check for in petsc once I localize it.
Geoffrey
