[petsc-users] neumann failure in my version of snes ex12
Geoffrey Irving
irving at naml.us
Fri Nov 22 18:42:23 CST 2013
On Fri, Nov 22, 2013 at 4:25 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Nov 22, 2013 at 6:09 PM, Geoffrey Irving <irving at naml.us> wrote:
>> On Fri, Nov 22, 2013 at 3:41 PM, Matthew Knepley <knepley at gmail.com>
>> wrote:
>> > On Fri, Nov 22, 2013 at 5:36 PM, Geoffrey Irving <irving at naml.us> wrote:
>> >> I have a duplicate of snes ex12 (FEM Poisson) which works with
>> >> Dirichlet boundary conditions, but it's breaking for me with Neumann
>> >> conditions. In particular, with Neumann conditions I get results
>> >> which explode even though I believe I am setting a constant nullspace.
>> >> For example, if I use two first order elements (the unit square
>> >> divided into two triangles), the resulting solution has
>> >> L2 error = 1.75514e+08
>> >> u = [-175513825.75680602, -175513825.66302037,
>> >> -175513825.48390722, -175513824.84436429]
>> >> This looks rather a lot like the null space isn't getting through. I
>> >> am creating the constant nullspace with
>> >> MatNullSpace null;
>> >> CHECK(MatNullSpaceCreate(comm(),PETSC_TRUE,0,0,&null));
>> >> CHECK(MatSetNullSpace(m,null));
>> >> CHECK(MatNullSpaceDestroy(&null));
>> >> If I pass "-ksp_view -mat_view", I get the following. The matrix
>> >> entries seem right (they do indeed have the constant nullspace), and
>> >> ksp_view shows that a nullspace is attached. Is attaching the
>> >> nullspace to the matrix with MatSetNullSpace enough, or do I need to
>> >> additionally attach it to the KSP object?
>> > 1) I always run with -ksp_monitor_true_residual now when debugging. This
>> > can
>> > give
>> > you an idea whether you have a singular PC, which I suspect here.
>> > 2) Can you try using -pc_type jacobi? I think ILU might go crazy on a
>> > deficient matrix.
>> Here are results with -ksp_monitor_true_residual -pc_type none:
>> http://naml.us/random/laplace-rtol.txt # with -ksp_rtol 1e-5
>> http://naml.us/random/laplace-atol.txt # with -ksp_atol 1e-5
> Okay, if you have an inconsistent RHS I do not think that true_residual will work
> since it uses the unprojected b, but the solve should be fine.
I still don't understand why the atol version is able to drift so far
away from zero mean, even after tens of thousands of iterations. If
KSP sees a null space on the matrix, shouldn't it project that null
space out of the *linear system* residual and also out of solution on
each iteration? Even if it is only projecting out of the solution
delta, how can null space errors be accumulating?
>> Is there a standard way to do this in the context of an SNES, where
>> I'm not computing the residual directly myself? Should I write a
>> wrapper around DMPlexComputeResidualFEM and pass the wrapper to
>> DMSNESSetFunctionLocal, or is there a way to tell SNES about the
>> nullspace directly? Is such a projection happening somewhere in snes
>> ex12?
> SNES will do it automatically. You can just call MatNullSpaceRemove().
I.e., SNES will call MatNullSpaceRemove automatically, or I should
manually in a wrapper around DMSNESSetFunctionLocal?
Geoffrey
