[petsc-users] neumann failure in my version of snes ex12
Fri Nov 22 18:27:21 CST 2013
On Fri, Nov 22, 2013 at 6:25 PM, Geoffrey Irving <irving at naml.us> wrote:
> On Fri, Nov 22, 2013 at 4:17 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > Geoffrey Irving <irving at naml.us> writes:
> >> Here are results with -ksp_monitor_true_residual -pc_type none:
> >>     http://naml.us/random/laplace-rtol.txt # with -ksp_rtol 1e-5
> >>     http://naml.us/random/laplace-atol.txt # with -ksp_atol 1e-5
> > Looks like the preconditioner is singular.
> The preconditioner is none: -pc_type none.
> >> Both versions converge in 3 iterations for the first SNES iteration,
> >> but the relative one starts to churn after that since the residual
> >> starts very small.  The true residual goes down to 4/3 and stagnates.
> >> Is there a convenient way to print out the RHS to see whether it has a
> >> component in the nullspace (which seems likely given the true residual
> >> stagnation)?
> > -snes_monitor_residual will plot the solution.  (This option should be
> >  upgraded to support arbitrary output formats.)  You can also call
> >  VecView from your residual function.
> >> I suppose I already do print the result of SNESComputeFunction on the
> >> zero vec, which is
> >>     RHS = [  6.66666667e-01   1.33333333e+00   6.66666667e-01
> 1.11022302e-16]
> > Looks like you need to project out the null space.
> Yep, I was hallucinating that analytically consistent implies
> discretely consistent.
> Is there a standard way to do this in the context of an SNES, where
> I'm not computing the residual directly myself?  Should I write a
> wrapper around DMPlexComputeResidualFEM and pass the wrapper to
> DMSNESSetFunctionLocal, or is there a way to tell SNES about the
> nullspace directly?  Is such a projection happening somewhere in snes
> ex12?
SNES will do it automatically. You can just call MatNullSpaceRemove().
   Matt
> Thanks,
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131122/b408c3c5/attachment.html>
