[petsc-users] neumann failure in my version of snes ex12
Jed Brown
jedbrown at mcs.anl.gov
Fri Nov 22 18:17:27 CST 2013
Geoffrey Irving <irving at naml.us> writes:
> Here are results with -ksp_monitor_true_residual -pc_type none:
> http://naml.us/random/laplace-rtol.txt # with -ksp_rtol 1e-5
> http://naml.us/random/laplace-atol.txt # with -ksp_atol 1e-5
Looks like the preconditioner is singular.
> Both versions converge in 3 iterations for the first SNES iteration,
> but the relative one starts to churn after that since the residual
> starts very small. The true residual goes down to 4/3 and stagnates.
> Is there a convenient way to print out the RHS to see whether it has a
> component in the nullspace (which seems likely given the true residual
> stagnation)?
-snes_monitor_residual will plot the solution. (This option should be
upgraded to support arbitrary output formats.) You can also call
VecView from your residual function.
> I suppose I already do print the result of SNESComputeFunction on the
> zero vec, which is
> RHS = [ 6.66666667e-01 1.33333333e+00 6.66666667e-01 1.11022302e-16]
Looks like you need to project out the null space.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131122/1e509702/attachment.pgp>
