[petsc-users] question about LU decomposition of a conjugated matrix
Jed Brown
jedbrown at mcs.anl.gov
Fri Nov 22 12:36:33 CST 2013
Michael, your time zone is mistakenly set to UTC, though the time is
actually set to CST, so your mails appear out of order.
Michael Povolotskyi <mpovolot at purdue.edu> writes:
> I'm actually interested in implementing it.
> Could you, please, tell what has to be done in MatMatSolveTranspose()?
> By transpose I mean transpose and complex conjugation.
Some time ago, Barry proposed adding a function like
MatSetTransposeType(A,MAT_TRANSPOSE_HERMITIAN) that would cause
MatMultTranspose(), MatSolveTranspose(), etc., to use Hermitian
transpose. The thought was that this was ultimately simpler to work
since the problem formulation usually dictates whether a complex matrix
uses a Hermitian transpose or not. Does that sound reasonable to you?
I can see two implementation strategies. One is to go into
MatLUFactor_SeqAIJ and set A->ops->transpose to a new function that
explicitly transposes the factors. The other is to copy MatMatSolve and
modify to be MatMatSolveTranspose, along with an implementation
MatMatSolveTranspose_SeqAIJ (and external packages if relevant).
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131122/5a19e440/attachment-0001.pgp>
