[petsc-users] question about LU decomposition of a conjugated	matrix
    Jed Brown
    jedbrown at mcs.anl.gov
    Fri Nov 22 12:07:20 CST 2013
Michael Povolotskyi <mpovolot at purdue.edu> writes:
> Dear developers of Petsc and users,
> I have the following numerical problem.
> I need to solve the system Ax = B, where A is a square matrix, x and B
> are rectangular matrix
> The system is solved by doing LU decomposition.
You can use MatLUFactor(), MatMatSolve().  There is no
MatMatSolveTranspose() at this time.
> In the next step I need to solve a system A'y = C, where A' is a complex
> conjugate of A.
> My question: is it possible to reuse the LU decomposition of A for doing
> this?
Not presently; you'd have to use MatHermitianTranspose() and refactor.
Support for reuse would not be very difficult to implement.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131122/d8cb5283/attachment.pgp>
