[petsc-users] GAMG processor reduction
Mark Adams mfadams at lbl.gov
Thu Nov 21 18:10:39 CST 2013
'-pc_gamg_verbose 2' will print out stuff where you can see the number of
active processors.  We have not been super motivated to use subcoms because
there are no norms taken on coarse grids, except in the eigen estimator for
cheby, unless you use krylov in the solver, which is not usually useful.
Jed: GAMG does reduce active processors by default.  I'm pretty sure.  I
assume that if you are using an iterative solver on the coarse grid that
you have a singular problem, and the AMG coarse grid space can represent it
exactly, so you have a singular matrix one the coarse grid.
On Thu, Nov 21, 2013 at 6:17 PM, Dave May <dave.mayhem23 at gmail.com> wrote:
> Exactly!
> My tests were performed on Kraken (Cray XT5) and a Cray XE6 and I was
> using iterative solvers on the coarse grid.
> On 22 November 2013 00:10, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> Dave May <dave.mayhem23 at gmail.com> writes:
>> > I argue it does matter as I've seen runs on 32k cores where a huge
>> amount
>> > of time is spent in those global reductions. I can provide an
>> > implementation which uses a sub comm (PCSemiRedundant) if someone thinks
>> > doing reductions on less cores is beneficial.
>> It doesn't matter much on Blue Gene, but is a big deal on older Crays.
>> Aires seems to be in between.  The default GAMG configuration doesn't do
>> any reductions in the coarse grid, so the issue is moot.  If an
>> iterative coarse solver was used, I think we would be more motivated to
>> put the coarse problem on a subcomm.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131121/31211f8b/attachment.html>
