[petsc-users] GAMG processor reduction
John Mousel
john.mousel at gmail.com
Thu Nov 21 13:39:39 CST 2013
I'm solving a Poisson equation with BiCGStab/GAMG. I'm looking at KSPView
and I see that the problem is not reducing the number of processors on the
coarser grids. My coarse problem is 723x723, and it looks like it's still
being solved on 192 processes. This doesn't seem right, and I'm believe
this used to trigger processor reduction. I'm running with
-pres_ksp_type bcgsl -pres_pc_type gamg -pres_pc_gamg_threshold 0.05
-pres_mg_levels_ksp_type richardson -pres_mg_levels_pc_type sor
-pres_mg_coarse_ksp_type richardson -pres_mg_coarse_pc_type sor
-pres_mg_coarse_pc_sor_its 5 -pres_pc_gamg_type agg
-pres_pc_gamg_agg_nsmooths 1 -pres_pc_gamg_sym_graph true -pres_ksp_monitor
-pres_ksp_view -pres_gamg_process_eq_limit 5000
The KSPView output is:
KSP Object:(pres_) 192 MPI processes
type: bcgsl
BCGSL: Ell = 2
BCGSL: Delta = 0
maximum iterations=1000, initial guess is zero
tolerances: relative=1e-06, absolute=1e-50, divergence=10000
left preconditioning
has attached null space
using PRECONDITIONED norm type for convergence test
PC Object:(pres_) 192 MPI processes
type: gamg
MG: type is MULTIPLICATIVE, levels=4 cycles=v
Cycles per PCApply=1
Using Galerkin computed coarse grid matrices
Coarse grid solver -- level -------------------------------
KSP Object: (pres_mg_coarse_) 192 MPI processes
type: preonly
maximum iterations=1, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000
using NONE norm type for convergence test
PC Object: (pres_mg_coarse_) 192 MPI processes
type: sor
SOR: type = local_symmetric, iterations = 5, local iterations = 1,
omega = 1
linear system matrix = precond matrix:
Mat Object: 192 MPI processes
type: mpiaij
rows=723, cols=723
total: nonzeros=519221, allocated nonzeros=519221
total number of mallocs used during MatSetValues calls =0
using I-node (on process 0) routines: found 499 nodes, limit used
is 5
Down solver (pre-smoother) on level 1 -------------------------------
KSP Object: (pres_mg_levels_1_) 192 MPI processes
type: richardson
Richardson: damping factor=1
maximum iterations=2
using nonzero initial guess
PC Object: (pres_mg_levels_1_) 192 MPI processes
type: sor
SOR: type = local_symmetric, iterations = 1, local iterations = 1,
omega = 1
type: mpiaij
rows=15231, cols=15231
total: nonzeros=4604432, allocated nonzeros=4604432
using I-node (on process 0) routines: found 33 nodes, limit used
is 5
Up solver (post-smoother) same as down solver (pre-smoother)
Down solver (pre-smoother) on level 2 -------------------------------
KSP Object: (pres_mg_levels_2_) 192 MPI processes
type: richardson
PC Object: (pres_mg_levels_2_) 192 MPI processes
type: sor
omega = 1
type: mpiaij
rows=242341, cols=242341
total: nonzeros=18277529, allocated nonzeros=18277529
not using I-node (on process 0) routines
Down solver (pre-smoother) on level 3 -------------------------------
KSP Object: (pres_mg_levels_3_) 192 MPI processes
type: richardson
PC Object: (pres_mg_levels_3_) 192 MPI processes
type: sor
omega = 1
type: mpiaij
rows=3285079, cols=3285079
total: nonzeros=48995036, allocated nonzeros=53586621
type: mpiaij
John
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131121/608ce839/attachment.html>
