[petsc-users] Problem with GAMG elasticity case:'createdefaultdata' not set(?) need to support NULL data!
Thu Nov 21 11:17:24 CST 2013
matsetsizes() is used practically everywhere - so I can't believe
there is a bug there. [the fortran interface code autogenerated by
bfort].
Do you see the error with the 'first' call to this routine - or some
subsequent loop?
Perhaps you can try using valgrind equivalent on windows to see if
there is memory corruption somewhere else.
http://stackoverflow.com/questions/413477/is-there-a-good-valgrind-substitute-for-windows
suggests using http://code.google.com/p/drmemory/
Satish
On Thu, 21 Nov 2013, Einar Sørheim wrote:
> I am on the windows platform so unfortunatley no valgrind, however have
> been able to track down the problem in the debugger and it seems like a
> matrixpointer gets corrupted when using the fortran-c interface in petsc.
> At some point in the calculation the matrix pointer in MatSetSize gets
> corrupted when called from fortran, propably in this cast:
> void PETSC_STDCALL  matsetsizes_(Mat A,PetscInt *m,PetscInt *n,PetscInt
> *M,PetscInt *N, int *__ierr ){
> *__ierr = MatSetSizes(
> (Mat)PetscToPointer((A) ),*m,*n,*M,*N);
> when entering the MatSetSize in the debugger the A-matrix pointer is
> corrupt and I get an access violation on code line:
>   PetscValidHeaderSpecific(A,MAT_CLASSID,1);
> Any ideas what may be the cause of this?
> Regards
> Einar
> 2013/10/24 Barry Smith <bsmith at mcs.anl.gov>
> >   So apparently no memory leak.
> >    If you are still getting crashes you will need to run the case that
> > crashes 1) with valgrind if you haven’t or 2) using
> > -on_error_attach_debugger or -start_in_debugger to track down the cause of
> > the crash.
> >    Barry
> > On Oct 24, 2013, at 2:09 AM, Einar Sørheim <einar.sorheim at gmail.com>
> > wrote:
> > > Well i I did a rerun without -malloc_log, this is what I got (I have
> > also attached the log-sumary file):
> > > [0] PetscFinalize(): PetscFinalize() called
> > > [0] PetscCommDuplicate(): Duplicating a communicator 1140850688
> > -2080374784 max tags = 2147483647
> > > Summary of Memory Usage in PETSc
> > > [0]Current space PetscMalloc()ed 45936, max space PetscMalloced()
> > 1.13728e+009
> > > [0]OS cannot compute process memory
> > > [0] PetscCommDuplicate(): Using internal PETSc communicator 1140850688
> > -2080374784
> > > [0] PetscGetHostName(): Rejecting domainname, likely is NIS CMP3.
> > > [0] PetscFOpen(): Opening file Log.0
> > > [0] Petsc_DelViewer(): Removing viewer data attribute in an MPI_Comm
> > -2080374784
> > > [0] Petsc_DelComm_Inner(): Removing reference to PETSc communicator
> > embedded in a user MPI_Comm -2080374784
> > > [0] Petsc_DelComm_Outer(): User MPI_Comm 1140850688 is being freed after
> > removing reference from inner PETSc comm to this outer comm
> > > [0] PetscCommDestroy(): Deleting PETSc MPI_Comm -2080374784
> > -2080374784
> > > [0] Petsc_DelThreadComm(): Deleting thread communicator data in an
> > > [0] Petsc_DelCounter(): Deleting counter data in an MPI_Comm -2080374784
> > > 2013/10/23 Barry Smith <bsmith at mcs.anl.gov>
> > >    Don’t run with the -malloc_log Mark did not suggest using that option.
> > > On Oct 23, 2013, at 8:48 AM, Einar Sørheim <einar.sorheim at gmail.com>
> > wrote:
> > > > I tried running with the following options :
> > > > -info
> > > > -malloc
> > > > -malloc_log
> > > > -malloc_dump
> > > > -malloc_debug
> > > > -memory_info
> > > > -log_summary log_summary.txt
> > > > -log
> > > > but didn't get a lot wiser however in my case would it be more
> > efficient to keep the ksp solver object, if so should I have one object eg.
> > for the thermal problem and another one for the mechanical?
> > > > The output from the end of the run:
> > > >  Total wall clock time actually solving:     856.231474
> > 1.13728e+009
> > -2080374784
> > -2080374784
> > after removing reference from inner PETSc comm to this outer comm
> > -2080374784
> > -2080374784
> > > > [0]PETSC ERROR: --------------------- Error Message
> > > > [0]PETSC ERROR: Object is in wrong state!
> > > > [0]PETSC ERROR: PetscMallocDumpLog() called without call to
> > PetscMallocSetDumpLog() this is often due to
> > > >                       setting the option -malloc_log AFTER
> > PetscInitialize() with PetscOptionsInsert() or PetscOptionsInsertFile()!
> > > > [0]PETSC ERROR:
> > > > [0]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
> > > > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > > > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > > > [0]PETSC ERROR: See docs/index.html for manual pages.
> > > > [0]PETSC ERROR:
> > > > [0]PETSC ERROR: D:\Programming\gits\Alsim\SharedModules -
> > Copy\Source\Release\Alsim_nypetsc.exe on a arch-mswin-c-debug named CMP3 by
> > admeinar Wed Oct 23 11:54:03 2013
> > > > [0]PETSC ERROR: Libraries linked from
> > /cygdrive/d/Programming/petsc-3.4.3/arch-mswin-c-debug/lib
> > > > [0]PETSC ERROR: Configure run at Thu Oct 17 08:23:18 2013
> > > > [0]PETSC ERROR: Configure options --with-debugging=1 --with-openmp=yes
> > --with-pthread=no --with-cc="win32fe icl" --with-fc="win32fe ifort"
> > --with-cxx="win32fe icl" --with-blas-lapack-dir="C:/Program Files
> > (x86)/Intel/Composer XE 2013/mkl/lib/intel64" --download-superlu
> > --with-sowing=0 --with-c2html=0 --with-mpi-dir="C:/Program Files
> > (x86)/Intel/MPI/4.1.0.028/em64t" --useThreads=0 --useThreads=0
> > > > [0]PETSC ERROR:
> > > > [0]PETSC ERROR: PetscMallocDumpLog() line 652 in
> > src/sys/memory/D:\PROGRA~1\PETSC-~1.3\src\sys\memory\mtr.c
> > > > [0]PETSC ERROR: PetscFinalize() line 1185 in
> > src/sys/objects/D:\PROGRA~1\PETSC-~1.3\src\sys\objects\pinit.c
> > > > 2013/10/19 Mark F. Adams <mfadams at lbl.gov>
> > > > You can try running a problem that finishes with
> > > > -malloc
> > > > -malloc_debug
> > > > -malloc_dump
> > > > to see if there are any memory issues.  It looks like you are
> > completely destroying the solver object each time and starting over.
> >  Valgrind would be very useful here because it looks like memory is getting
> > corrupted if the same code runs many times.
> > > > On Oct 19, 2013, at 3:39 PM, Einar Sørheim <einar.sorheim at gmail.com>
> > wrote:
> > > >> yes, I call the given code many times, what i have seen so far is
> > that changing e.g. the order of destruction statements changes the time of
> > failure,I will try to debug to get more details
> > > >> 2013/10/18 Mark F. Adams <mfadams at lbl.gov>
> > > >> I would guess there is some memory corruption or leak someplace.  Try
> > running with -on_error_attach_debugger, and try to get some more
> > information.  Do you just repeat a call to the code below many times?  Is
> > this deterministic, does it fail on the same solve each time?
> > > >> On Oct 18, 2013, at 9:30 AM, Einar Sørheim <einar.sorheim at gmail.com>
> > wrote:
> > > >>> Uncommenting  KSPSetFromOptions solved my intial problem, however I
> > got a new problem that occurs after many timesteps, in our code we use
> > petsc gamg as a solver for several problems(e.g. thermal and mechanical) at
> > each time step, I have a suspicion it might have something to do with
> > cleanup after solving, the rror appears after many calls to the petsc gamg
> > solver interface, the error message is the following:
> > > >>> [0]PETSC ERROR:
> > > >>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
> > Violation, probably memory access out of range
> > > >>> [0]PETSC ERROR: Try option -start_in_debugger or
> > > >>> [0]PETSC ERROR: or see
> > http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[0]PETSCERROR: or try
> > http://valgrind.org on GNU/linux and Apple Mac OS X to find memory
> > corruption errors
> > > >>> [0]PETSC ERROR: likely location of problem given in stack below
> > > >>> [0]PETSC ERROR: ---------------------  Stack Frames
> > > >>> [0]PETSC ERROR: Note: The EXACT line numbers in the stack are not
> > available,
> > > >>> [0]PETSC ERROR:       INSTEAD the line number of the start of the
> > function
> > > >>> [0]PETSC ERROR:       is given.
> > > >>> [0]PETSC ERROR: [0] MatSetNearNullSpace line 7580
> > src/mat/interface/D:\PROGRA~1\PETSC-~1.3\src\mat\INTERF~1\matrix.c
> > > >>> [0]PETSC ERROR: Signal received!
> > > >>> [0]PETSC ERROR:
> > > >>> [0]PETSC ERROR:
> > admeinar Fri Oct 18 12:26:04 2013
> > --with-openmp=yes --with-pthread=no --with-cc="win32fe icl"
> > --with-fc="win32fe ifort" --with-cxx="win32fe icl"
> > --with-blas-lapack-dir="C:/Program Files (x86)/Intel/Composer XE
> > 2013/mkl/lib/intel64" --download-superlu --with-sowing=0 --with-c2html=0
> > --with-mpi-dir="C:/Program Files (x86)/Intel/MPI/4.1.0.028/em64t"
> > > >>> The source code for the petsc interface:
> > > >>>       subroutine
> > petscsolver(i_nodes,r_elements_,i_rowstart_,i_columnindex_,r_x_,r_b_,i_Nnz,i_Precond,
> > i_Solver
> > > >>>      $     ,coords_,i_nodedof)
> > > >>> #include <finclude/petscsys.h>
> > > >>> #include <finclude/petscvec.h>
> > > >>> #include <finclude/petscmat.h>
> > > >>> #include <finclude/petscpc.h>
> > > >>> #include <finclude/petscksp.h>
> > > >>> #include <finclude/petscviewer.h>
> > > >>>       integer i_nodes, i_Nnz, i_Precond, i_solver, i_nodedof
> > > >>>       integer i_rowstart_(*),i_columnindex_(*)
> > > >>>       double precision r_elements_(*),r_x_(*), r_b_(*),coords_(*)
> > > >>>       integer, allocatable  :: i_indices_(:)
> > > >>> !     Variables:
> > > >>> !  A       - matrix that defines linear system
> > > >>> !  ksp    - KSP context
> > > >>> !  ksp     - KSP context
> > > >>> !  x, b, u - approx solution, RHS, exact solution vectors
> > > >>> !      implicit none
> > > >>>       Vec     x,u,b,vec_coords
> > > >>>       PC      pc
> > > >>>       Mat     A,F,Matnull
> > > >>>       KSP    ksp
> > > >>>       PetscInt i,j,II,JJ,m,n,i1,imaxiter
> > > >>>       PetscInt Istart,Iend
> > > >>>       PetscInt nsteps,one, neg_one
> > > >>>       PetscErrorCode ierr
> > > >>>       PetscBool  flg
> > > >>>       PetscScalar  v,x_array_(1), norm, tol, t0,t1
> > > >>>       PetscOffset i_x
> > > >>>       PetscViewer viewer
> > > >>>       call PetscTime(t0,ierr)
> > > >>>       write(*,*) "Enter petsc"
> > > >>>       n      = 1
> > > >>>       nsteps = 1
> > > >>>       one    = 1
> > > >>>       neg_one = 1
> > > >>>       i1 = 1
> > > >>>       imaxiter = 1200
> > > >>>       call MatCreate(PETSC_COMM_WORLD,A,ierr)
> > > >>>       call
> > MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,i_nodes,i_nodes,ierr)
> > > >>>       call MatSetType(A, MATSEQAIJ,ierr)
> > > >>>       call MatSetUp(A,ierr)
> > > >>>       call MatSeqAIJSetPreallocation(A,100,PETSC_NULL_INTEGER,ierr)
> > > >>> !  The matrix is partitioned by contiguous chunks of rows across the
> > > >>> !  processors.  Determine which rows of the matrix are locally owned.
> > > >>>       call MatGetOwnershipRange(A,Istart,Iend,ierr)
> > > >>>       write(*,*) "Start of matrix fill", i_nodes, Istart, Iend
> > > >>>       do i=1,i_nodes
> > > >>> !         write(*,*) "Start of loop",i !!, i_indices_(i+1)
> > > >>> !         i_indices_(i+1) = i
> > > >>> !         write(*,*) "Start of loop2"
> > > >>>          do j=i_rowstart_(i),i_rowstart_(i+1)-1
> > > >>> !            write(*,*) "Start of loop 3"
> > > >>>             v = r_elements_(j)
> > > >>> !            write(*,*) i1,i,i1,j-1,v
> > > >>>             call
> > MatSetValues(A,i1,i-1,i1,i_columnindex_(j)-1,v,INSERT_VALUES,ierr)
> > > >>>             if (ierr.gt.0) stop
> > > >>>          end do
> > > >>>       end do
> > > >>> !      write(*,*) "End of matrix fill"
> > > >>> !  Assemble matrix, using the 2-step process:
> > > >>> !       MatAssemblyBegin(), MatAssemblyEnd()
> > > >>> !  Computations can be done while messages are in transition
> > > >>> !  by placing code between these two statements.
> > > >>>       call MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY,ierr)
> > > >>>       call MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY,ierr)
> > > >>> !  Create parallel vectors.
> > > >>> !   - When using VecCreate(), the parallel partitioning of the vector
> > > >>> !     is determined by PETSc at runtime.
> > > >>> !   - Note: We form 1 vector from scratch and then duplicate as
> > needed.
> > > >>> !      write(*,*) "Start of vector fill"
> > > >>>       call VecCreate(PETSC_COMM_WORLD,u,ierr)
> > > >>>       call VecSetType(u, VECSEQ,ierr)
> > > >>>       call VecSetSizes(u,PETSC_DECIDE,i_nodes,ierr)
> > > >>> !      call VecSetFromOptions(u,ierr)
> > > >>>       call VecDuplicate(u,b,ierr)
> > > >>>       call VecDuplicate(b,x,ierr)
> > > >>>       do i=1,i_nodes
> > > >>>          call VecSetValues(x,i1,i-1,r_x_(i),INSERT_VALUES,ierr)
> > > >>>          call VecSetValues(b,i1,i-1,r_b_(i),INSERT_VALUES,ierr)
> > > >>>       enddo
> > > >>> !  Assemble vector
> > > >>>        call VecAssemblyBegin(x,ierr)
> > > >>>        call VecAssemblyEnd(x,ierr)
> > > >>>        call VecAssemblyBegin(b,ierr)
> > > >>>        call VecAssemblyEnd(b,ierr)
> > > >>>        call PetscTime(t1,ierr)
> > > >>> !       write(*,*) "End of vec fill time spent :", t1-t0
> > > >>> !  Create linear solver context
> > > >>>       call KSPCreate(PETSC_COMM_WORLD,ksp,ierr)
> > > >>> !  Set operators. Here the matrix that defines the linear system
> > > >>> !  also serves as the preconditioning matrix.
> > > >>>       call KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN,ierr)
> > > >>>       call KSPGetPC(ksp,pc,ierr)
> > > >>>       tol = 1.e-20
> > > >>>       call
> > KSPSetTolerances(ksp,tol,PETSC_DEFAULT_DOUBLE_PRECISION,PETSC_DEFAULT_DOUBLE_PRECISION,imaxiter,ierr)
> > > >>>       select case (i_Precond)
> > > >>>       case ( 1 )
> > > >>>          call PCSetType(pc,PCJACOBI,ierr)
> > > >>>       case ( 2 )
> > > >>>          call PCSetType(pc,PCILU,ierr)
> > > >>>          call PCFactorSetMatSolverPackage(pc,MATSOLVERSUPERLU,ierr);
> > > >>>          call PCFactorSetUpMatSolverPackage(pc,ierr);
> > > >>>          call PCFactorGetMatrix(pc,F);
> > > >>>          call MatSuperluSetILUDropTol(F,1.e-4);
> > > >>>       case ( 3 )
> > > >>>          call PCSetType(pc,PCGAMG,ierr)
> > > >>> !         call PCGAMGInitializePackage()
> > > >>> !         call PCCreate_GAMG(pc,ierr)
> > > >>>       case DEFAULT
> > > >>>       end select
> > > >>> !      call PCSetType(pc,PCJACOBI,ierr)
> > > >>>       select case (i_solver)
> > > >>>       case ( 0 )
> > > >>>          call KSPSetType(ksp,KSPCG,ierr)
> > > >>>       case DEFAULT
> > > >>>       end select
> > > >>>       call KSPCGSetType(ksp,KSP_CG_SYMMETRIC,ierr)
> > > >>>       if (i_nodedof==3) then
> > > >>>          write(*,*) "Set coord, number of nodes is:",
> > i_nodes/i_nodedof
> > > >>>          call
> > VecCreateSeqWithArray(MPI_COMM_SELF,3,i_nodes,coords_,vec_coords,ierr)
> > > >>>          call MatNullSpaceCreateRigidBody(vec_coords,Matnull,ierr)
> > > >>>          call MatSetNearNullSpace(A,Matnull,ierr)
> > > >>>          call MatNullSpaceDestroy(Matnull,ierr)
> > > >>>          write(*,*) "Finish setting null space ierr =", ierr
> > > >>> !         call PCSetCoordinates( pc, 3,i_nodes/i_nodedof, coords_,
> > ierr )
> > > >>>       end if
> > > >>> !      call KSPMonitorSet(ksp, KSPMonitorDefault, PETSC_NULL,
> > PETSC_NULL,ierr)
> > > >>> !  Set runtime options, e.g.,
> > > >>> !      -ksp_type <type> -pc_type <type> -ksp_monitor -ksp_rtol <rtol>
> > > >>> !  These options will override those specified above as long as
> > > >>> !  KSPSetFromOptions() is called _after_ any other customization
> > > >>> !  routines.
> > > >>>       call KSPSetFromOptions(ksp,ierr)
> > > >>>       call KSPSetInitialGuessNonzero(ksp,PETSC_TRUE,ierr)
> > > >>>       call KSPSetUp(ksp,ierr)
> > > >>>       write(*,*) "Time setup", t0-t1
> > > >>> !                      Solve the linear system
> > > >>>       call KSPSolve(ksp,b,x,ierr)
> > > >>>       write(*,*) "end solve, time used:",t1-t0
> > > >>>       call KSPGetSolution(ksp,x,ierr)
> > > >>>       call VecGetArray(x,x_array_,i_x,ierr)
> > > >>>       do i=1,i_nodes
> > > >>>          r_x_(i) = x_array_(i_x + i)
> > > >>>       enddo
> > > >>>       call VecRestoreArray(x,x_array_,i_x,ierr)
> > > >>> !  Free work space.  All PETSc objects should be destroyed when they
> > > >>> !  are no longer needed.
> > > >>> !      call PCDestroy(pc,ierr)
> > > >>>       call VecDestroy(u,ierr)
> > > >>>       call VecDestroy(x,ierr)
> > > >>>       call VecDestroy(b,ierr)
> > > >>>       call MatDestroy(A,ierr)
> > > >>>          call VecDestroy(vec_coords,ierr)
> > > >>>          call MatDestroy(Matnull,ierr)
> > > >>>       endif
> > > >>>       call KSPDestroy(ksp,ierr)
> > > >>>       write(*,*) "time celan up :", t0-t1
> > > >>>       end
> > > >>> Einar Sørheim
> > > >>> <Mail Attachment>
> > > >> Einar Sørheim
> > > > Einar Sørheim
> > > Einar Sørheim
> > > <log_summary.txt>
