[petsc-users] KSPSetDM problem
Jed Brown
jedbrown at mcs.anl.gov
Fri Nov 15 17:49:56 CST 2013
Michele Rosso <mrosso at uci.edu> writes:
> Barry,
> thank you.
> I have another question: how does petsc compute the restriction
> (assuming the user does not supply his own restriction)?
> Does it use a simple transpose of the interpolation operator?
Yes, it uses the same.
> Could you point me to the source code where this is done?
See the implementation of PCMGGetInterpolation and PCMGGetRestriction.
If you only provide one, the other will use it.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131115/8291340f/attachment.pgp>
