[petsc-users] snes ex12 question about DMPlexProjectFunctionLocal
Matthew Knepley
knepley at gmail.com
Thu Nov 14 20:22:36 CST 2013
On Thu, Nov 14, 2013 at 8:16 PM, Geoffrey Irving <irving at naml.us> wrote:
> On Thu, Nov 14, 2013 at 6:08 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
> > On Thu, Nov 14, 2013 at 7:38 PM, Geoffrey Irving <irving at naml.us> wrote:
> >> On Thu, Nov 14, 2013 at 5:35 PM, Matthew Knepley <knepley at gmail.com>
> >> wrote:
> >> > On Thu, Nov 14, 2013 at 7:32 PM, Geoffrey Irving <irving at naml.us>
> wrote:
> >> >> If this line in ex12 is part of Dirichlet boundary conditions, why is
> >> >> it done unconditionally even for Neumann? Is this a mistake that
> >> >> fails to test correct Neumann conditions?
> >> >> ierr = DMPlexProjectFunctionLocal(dm, user.fe, user.exactFuncs,
> >> >> INSERT_BC_VALUES, userJ.u);CHKERRQ(ierr);
> >> > No, its just idempotent in that case.
> >> That's what I meant by fail to test: if there was a bug related to
> >> null spaces, it wouldn't show up in this example.
> > I do not understand. If you have Neumann conditions, nothing happens, so
> > it would check that case.
> I may be misunderstanding something, but wouldn't nothing happen only
> if the rest of the code is correct?
Nothing would happen as long as you have not set any Dirichlet conditions.
Matt
> Geoffrey
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131114/5d3110dd/attachment.html>
