[petsc-users] Unable to create >4GB sized HDF5 files on Cray XC30
Juha Jäykkä
juhaj at iki.fi
Tue Nov 12 04:37:13 CST 2013
Hi Jed,
Let's see what comes of this... I forked petsc/petsc and created a pull
request. There are probably loads of unneeded casts and at least one "+1" just
to make sure I'm not rounding a float down into an integer under any
circumstances.
> Thanks, the logic looks reasonable. Unfortunately, I don't think we can
> have comprehensive tests because the large file sizes won't work in many
> test environments. That said, we could have a configurable parameter
> instead of hard-coding 4 GiB, in which case we could set it to 1 MiB (or
> less) for testing.
I'll leave the parameter for others to implement: I don't have a good idea of
how to do that. I believe I can provide a testing environment (but no access
to it, I'm afraid) for those big files, just let me know what kind of test
suite I should create. Not that the old chunking seems to have had much
testing considering how seriously broken it is. ;)
> > + // just in case some libraries do not empty memory for local variables:
> We have to use C89-style comments because of Microsoft.
What is this, Microsoft's compiler cannot do C99? Is it too new a standard, at
14 years old?
> > + // some requirements for the chunks (assuming no split along time-step)
> > + int ranks;
> Declarations cannot be mixed with statements in C89.
Microsoft again? I've reverted these *standard* pieces of code into an
obsolete, old standard. I really had no idea there are STILL compilers around
which cannot do C99.
> PetscObjectComm((PetscObject)xin). And please name the variable "size"
> or "comm_size".
Done.
> One reasonable thing is to write
> hsize_t Ki = 1024;
> and then
> Gi = Ki*Ki*Ki;
Done.
> I would prefer to move all the logic below into a function
> VecGetHDF5ChunkSize(). Note that almost the same logic appears in
Done.
> Please use PetscMax() and PetscMin(). You can define the 3-way versions
> at the top of the file if need be.
Done. I also removed the 3-way versions.
> You mixed tabs and spaces here. Please use all spaces.
Probably forgot. =) I mostly write python, so I'm very surprised I managed to
mix tabs and spaces, considering how nice side-effects that often has in
python.
I hope this works and can get to the next release.
Cheers,
Juha
Desc: This is a digitally signed message part.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131112/1c5037bb/attachment.pgp>
