[petsc-users] stensils
Gryllida
gryllida at fastmail.fm
Thu Nov 7 17:40:00 CST 2013
On Thu, 7 Nov 2013, at 17:09, Gryllida wrote:
> http://courses.engr.illinois.edu/cs554/fa2011/notes/petscpde.pdf has a "this is a simple but inefficient way to set up the matrix" at slide 18. Later they set it as a stensil instead. What is a recommended example of doing the same with OPENMP in FORTRAN, if I have matrices A_central, A_top, A_bottom, A_left, A_right, containing the stensil items?
> Svetlana
Sent that to petsc-dev as the stable version doesn't support openmp. Apologies for sending to the wrong list initially.
