[petsc-users] --with-hypre-dir did not work for petsc configure in Win-7
Satish Balay
balay at mcs.anl.gov
Thu Nov 7 09:20:16 CST 2013
On Thu, 7 Nov 2013, Qin Lu wrote:
> Satish,
> I tried what you suggested for petsc configure but it still did not work. See the attached configure.log.
> How did you see I was using gcc for hypre?
For cl/icl the library should be libhypre.lib or hypre.lib [not libhypre.a]
> I think I used Intel compiler icl since I specified "CC=icl CXX=icl" for hypre configure. I double-checked hypre's Makefile.config and CC and CXX are icl.
If you follow the instructions I copy/pasted in my previous e-mail regarding 'windows' installation
- there is no mention of using configure - but of using cmake. [I think you have to install/use native
windows cmake - not the one from cygwin]
Satish
> Thanks,
> Qin
> On Wednesday, November 6, 2013 6:37 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> For one - the --with-hypre-lib would be:
> --with-hypre-lib=/cygdrive/c/Lib/hypre-2.8.0b-win64-release/lib/libHYPRE.a
> However - it appears you built hypre with gcc - not icc [which I thought was your goal]
> If gcc/gfortran would work - you might as well install hypre via petsc configure [--download-hypre]
> Satish
> > Satis,
> > 1. hypre-2.9 did not build in Win-7 for some reason, so I still use hypre-2.8.0b.
> > 2. I used CXXFLAGS="-O2 -MT" for hypre configure.
> > 3. Tried --with-hypre-include and --with-hypre-lib but still got error:
> > =============================================================================== TESTING: check from config.libraries(config/BuildSystem/config/libraries.py:145) *******************************************************************************
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> > --with-hypre-lib=['/cygdrive/c/Lib/hypre-2.8.0b-win64-release/lib'] and
> > --with-hypre-include=['/cygdrive/c/Lib/hypre-2.8.0b-win64-release/include'] did not work
> > 4. Content of hypre installation:
> > $ ls -R /cygdrive/c/Lib/hypre-2.8.0b-win64-release
> > /cygdrive/c/Lib/hypre-2.8.0b-win64-release:
> > include lib
> > /cygdrive/c/Lib/hypre-2.8.0b-win64-release/include:
> > Data.h HYPRE_krylov.h HYPRE_struct_mv.h _hypre_IJ_mv.h csr_block_matrix.h par_csr_block_matrix.h
> > HYPRE.h HYPRE_lobpcg.h HYPREf.h _hypre_parcsr_ls.h csr_matmultivec.h par_csr_matmultivec.h
> > HYPRE_DistributedMatrixPilutSolver_protos.h HYPRE_matrix_matrix_protos.h LLNL_FEI_Fei.h _hypre_parcsr_mv.h distributed_matrix.h par_csr_pmvcomm.h
> > HYPRE_DistributedMatrixPilutSolver_types.h HYPRE_parcsr_ls.h LLNL_FEI_Impl.h _hypre_sstruct_ls.h fei_defs.h par_multivector.h
> > HYPRE_FEI_includes.h HYPRE_parcsr_mv.h LLNL_FEI_LSCore.h _hypre_sstruct_mv.h hypre_cfei.h seq_multivector.h
> > HYPRE_IJ_mv.h HYPRE_seq_mv.h LLNL_FEI_Matrix.h _hypre_struct_ls.h interpreter.h seq_mv.h
> > HYPRE_LinSysCore.h HYPRE_sstruct_ls.h LLNL_FEI_Solver.h _hypre_struct_mv.h krylov.h temp_multivector.h
> > HYPRE_MatvecFunctions.h HYPRE_sstruct_mv.h LinearSystemCore.h cfei-hypre.h lobpcg.h
> > HYPRE_config.h HYPRE_struct_ls.h Lookup.h cfei_hypre.h multivector.h
> > /cygdrive/c/Lib/hypre-2.8.0b-win64-release/lib:
> > libHYPRE.a
> > 5. I used compilation option -O3 for PETSc, but -O2 for hypre, can this be a problem?
> > Thanks,
> > Qin
> > On Wednesday, November 6, 2013 4:11 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > 1. use latest hypre version - i.e
> > https://computation.llnl.gov/casc/hypre/download/hypre-2.9.1a.tar.gz
> > 2. Make sure its buit with -MT compiler option
> > 3. specify hypre with --with-hypre-include and --with-hypre-lib options
> > 4. send us the following [so we know whats there - and why configure is not finding it]
> > Satish
> > On Wed, 6 Nov 2013, Qin Lu wrote:
> > > Hello,
> > > I have built hypre-2.8.0b in Win-7 and have put the installlation under C:\Lib\hypre-2.8.0b-win64-release. Now I want to include it in my PETSc build but PETSc configure (within cygwin) gave an error message:
> > > --with-hypre-dir=/cygdrive/c/Lib/hypre-2.8.0b-win64-release did not work
> > > The configure.log is attached.
> > > Many thanks for any suggestions,
> > > Qin
